- WAPT version installed: 2.5
- Server OS: Linux 22.04
- Administration/package creation machine OS: Windows Server 2016
I'm using the Discovery version and I'd like to know if there's a way to deploy scripts (.ps1, .bat, etc.) to agent machines? If so, is there any documentation to guide me, as I haven't been able to find it online?
Thank you!
[SOLVED] Deploying Script on WAPT
thirst_for_knowledge
- Registration: December 5, 2024 - 3:33 PM
- Installed WAPT version: 2.6.0.16714
- Server OS: Ubuntu
- Administration machine OS: Windows Server 2019
- Server OS: Ubuntu
this will run using the `run()` or `run_not_fatal()` commands for batch files, and `run_powershell`, `run_powershell_from_file()`, or `run_powershell_script()` for PS1 files.
https://www.wapt.fr/apidoc/wapt-2.5/win ... elpers.run
Have a good day,
Bertrand
Have a good day,
Bertrand
Hello Bertrand,blemoigne wrote: ↑Dec 6, 2024 - 2:17 PM Hello,
it will run with the commands run() or run_not_fatal() for batch files, run_powershell, run_powershell_from_file() or run_powershell_script() for PS1 files.
Have a good day,
Bertrand
Sorry if my questions seem stupid and the answers seem obvious to you.
I am really a beginner with the software and I would like to know a little more detail in order to be able to deploy a script.
- Do I need to generate an empty package template in the WAPT console for this type of work?
- How (or where) can I edit a package via command lines?
Thank you !
- Server OS: Ubuntu
- Server OS: Ubuntu
First, you need to make sure you have a development environment installed:
https://www.wapt.fr/fr/doc/wapt-create- ... pt-console
Then, you need to create an empty package. By default, the directory for the package under development is located in c:\waptdev.
You can then put the scripts in the package directory.
Have a good weekend,
Bertrand
Bertrand
I successfully deployed a .bat file using the command:blemoigne wrote: ↑Dec 6, 2024 - 6:01 PM First, you need to make sure you have installed a development environment:
You can put the scripts in the package directory.
Bertrand
run(r"mon_script.bat")Code: Select all
run_powershell(r"mon_script.ps1")- Installed WAPT version: 2.6.0.16714
- Server OS: Ubuntu
- Server OS: Ubuntu
fschelfaut
- Registration: Nov 7, 2024 - 12:22
The function run_powershell() Waiting for a PowerShell command to execute.
To run a script *.ps1You must use the dedicated function: run_powershell_script().
Here are some examples of use:
All functions usable in a WAPT package are documented here
- https://www.wapt.fr/apidoc/wapt-2.6/win ... ell_script
- https://www.wapt.fr/apidoc/wapt-2.6/win ... powershell
Flavien
run_powershell_script("mon_script.ps1")
run_powershell('Write-Host "Je suis un test"')
Flavien
I keep getting errors related to the deployment of .ps1 scripts
In the empty package located at C:\waptdev, where I placed my test.ps1 scripts file:
Here is the code in setup.py:
Next, I created the package using the command in cmd:
On the empty package, I configured the architecture to x64 and the target OS to Windows.
When I deploy it, this error code appears:
Note that I did test manually launching the script on the host PC and it works correctly.
I also tested with the argument run_powershell_script(r"test.ps1", output_format='text') without knowing what it really does, the package is launched without any problem but the script does not work on the host.
Do you have any ideas on this problem that could help me? Thank you!
$sourceFilePath = "\\lan.xxx.xxx\NETLOGON\GPOs\Scripts\TEST WAPT\test.txt"
$destinationFilePath = "C:\test.txt"
if (Test-Path -Path $destinationFilePath) {
exit
} else {
Copy-Item -Path $sourceFilePath -Destination $destinationFilePath -Force
}Code: Select all
run_powershell_script(r"test.ps1")Code: Select all
wapt-get build-package C:\waptdev\idvet-testscript_1.0.0_x64_Windows_PROD-waptWhen I deploy it, this error code appears:
https://xxx.xxx.xxx.xxx/wapt/idvet-testscript_1.0.0-0_x64_windows_PROD.wapt : 5522 / 5522 (100%) (15 KB/s)
Erreur lors de l'installation de ['idvet-testscript(=1.0.0-0)']: erreurs dans les paquets [[PackageRequest(package='idvet-testscript',version=(Version('1.0.0.0'), 0),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('idvet-testscript','1.0.0-0' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1237, in run_powershell\n return json.loads(\'\\n\'.join(lines))\n File "json\\__init__.py", line 357, in loads\n File "json\\decoder.py", line 337, in decode\n File "json\\decoder.py", line 355, in raw_decode\njson.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\wapt8smn47lj\\setup.py", line 5, in install\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1266, in run_powershell_script\n return run_powershell(\'(invoke-expression -Command "%s")\' % script_filename, output_format, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1239, in run_powershell\n raise ValueError(\'%s returned non json data:\\n%s\\n%s\' % (cmd, result, e))\nValueError: "C:\\Windows\\system32\\WindowsPowerShell\\v1.0\\powershell.exe" -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "JABQAHIAbwBnAHIAZQBzAHMAUAByAGUAZgBlAHIAZQBuAGMAZQAgAD0AIAAiAFMAaQBsAGUAbgB0AGwAeQBDAG8AbgB0AGkAbgB1AGUAIgAKACgAaQBuAHYAbwBrAGUALQBlAHgAcAByAGUAcwBzAGkAbwBuACAALQBDAG8AbQBtAGEAbgBkACAAIgB0AGUAcwB0AC4AcABzADEAIgApACAAIAB8ACAAQwBvAG4AdgBlAHIAdABUAG8ALQBKAHMAbwBuACAA" returned non json data:\n#< CLIXML\r\n<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><S S="Error">test.ps1 : Le terme «test.ps1» n\'est pas reconnu comme nom d\'applet de commande, fonction, fichier de script ou _x000D__x000A_</S><S S="Error">programme exécutable. Vérifiez l\'orthographe du nom, ou si un chemin d\'accès existe, vérifiez que le chemin d\'accès _x000D__x000A_</S><S S="Error">est correct et réessayez._x000D__x000A_</S><S S="Error">Au caractère Ligne:1 : 1_x000D__x000A_</S><S S="Error">+ test.ps1_x000D__x000A_</S><S S="Error">+ ~~~~~~~~_x000D__x000A_</S><S S="Error"> + CategoryInfo : ObjectNotFound: (test.ps1:String) [], CommandNotFoundException_x000D__x000A_</S><S S="Error"> + FullyQualifiedErrorId : CommandNotFoundException_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>\nExpecting value: line 1 column 1 (char 0)\n']]
self._run()
Exception: Erreur lors de l'installation de ['idvet-testscript(=1.0.0-0)']: erreurs dans les paquets [[PackageRequest(package='idvet-testscript',version=(Version('1.0.0.0'), 0),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('idvet-testscript','1.0.0-0' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1237, in run_powershell\n return json.loads(\'\\n\'.join(lines))\n File "json\\__init__.py", line 357, in loads\n File "json\\decoder.py", line 337, in decode\n File "json\\decoder.py", line 355, in raw_decode\njson.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\wapt8smn47lj\\setup.py", line 5, in install\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1266, in run_powershell_script\n return run_powershell(\'(invoke-expression -Command "%s")\' % script_filename, output_format, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1239, in run_powershell\n raise ValueError(\'%s returned non json data:\\n%s\\n%s\' % (cmd, result, e))\nValueError: "C:\\Windows\\system32\\WindowsPowerShell\\v1.0\\powershell.exe" -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "JABQAHIAbwBnAHIAZQBzAHMAUAByAGUAZgBlAHIAZQBuAGMAZQAgAD0AIAAiAFMAaQBsAGUAbgB0AGwAeQBDAG8AbgB0AGkAbgB1AGUAIgAKACgAaQBuAHYAbwBrAGUALQBlAHgAcAByAGUAcwBzAGkAbwBuACAALQBDAG8AbQBtAGEAbgBkACAAIgB0AGUAcwB0AC4AcABzADEAIgApACAAIAB8ACAAQwBvAG4AdgBlAHIAdABUAG8ALQBKAHMAbwBuACAA" returned non json data:\n#< CLIXML\r\n<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><S S="Error">test.ps1 : Le terme «test.ps1» n\'est pas reconnu comme nom d\'applet de commande, fonction, fichier de script ou _x000D__x000A_</S><S S="Error">programme exécutable. Vérifiez l\'orthographe du nom, ou si un chemin d\'accès existe, vérifiez que le chemin d\'accès _x000D__x000A_</S><S S="Error">est correct et réessayez._x000D__x000A_</S><S S="Error">Au caractère Ligne:1 : 1_x000D__x000A_</S><S S="Error">+ test.ps1_x000D__x000A_</S><S S="Error">+ ~~~~~~~~_x000D__x000A_</S><S S="Error"> + CategoryInfo : ObjectNotFound: (test.ps1:String) [], CommandNotFoundException_x000D__x000A_</S><S S="Error"> + FullyQualifiedErrorId : CommandNotFoundException_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>\nExpecting value: line 1 column 1 (char 0)\n']]
self._run()
- Server OS: Ubuntu
- Server OS: Ubuntu
I finally found a solution to run the script. Here is my code in the setup.py file to run the test.ps1 script located in the empty WAPT package:
Thank you and have a good day!
import os # Import du module os pour gérer les chemins
Cette fonction est exécutée lors de l'installation du paquet.
current_dir = os.getcwd()
script_path = os.path.join(current_dir, "test.ps1")
# Exécuter le script PowerShell
run(f"powershell.exe -ExecutionPolicy Bypass -File \"{script_path}\"")
Cette fonction peut être utilisée pour désinstaller si nécessaire.
print("Uninstallation is not defined for this package.")- Installed WAPT version: 2.6.0.16714
- Server OS: Ubuntu
- Server OS: Ubuntu
