a package installed using the command "WAPT.install_wapt" generates the error:
Exception: No control found for (the name of the package to install).
However, the same package installed directly installs without any problem!
Thank you for your help.
Exception: No control found for...
Additional information is available in the notifications, which will display the following message:sfoy wrote:Hello,
CRITICAL waptservice.py: error 2052
It's better to use install than install_wapt
install_wapt() assumes that the package is already downloaded.
install() takes a package name (or the path to a local .wapt file) as a parameter
WAPT.install('monpaquet')Tranquil IT
That's what I ended up doing.
htouvet wrote:It's better to use install than install_wapt
def install(): WAPT.install('monpaquet')
