[SOLVED] Schneider Vijeo Designer Package
Gaelds
Registration: Nov 22, 2015 - 08:37
January 27, 2025 - 3:19 PM
I'm experiencing strange behavior when installing the Vijeo Designer MSI file. `install_msi_if_needed()` opens a popup displaying the software version, and I have to click OK.
After clicking OK, the installation completes successfully. However, the remotely installed package displays these errors in the console:
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1615, in install_msi_if_needed
    run(r'"%s" /norestart /q /i "%s" %s' % (makepath(system32(),'msiexec.exe'), msi, props), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2212, in run
waptutils.CalledProcessErrorOutput: Command '"C:\\WINDOWS\\system32\\msiexec.exe" /norestart /q /i "Vijeo Designer 6.3.0.msi" ' returned non-zero exit status 1618.
Output:U n   a u t r e   p r o g r a m m e   e s t   e n   c o u r s   d  i n s t a l l a t i o n .   A t t e n d e z   l a   f i n   d e   l  i n s t a l l a t i o n ,   p u i s   e s s a y e z   d e   r Ú i n s t a l l e r   c e   l o g i c i e l .
Gaelds
January 27, 2025 - 3:37 PM
The setup.exe file does the same thing with "/S /v/qn"
jlepiquet
Registration: Sep 3, 2024 - 4:09 p.m.
February 3, 2025 - 10:00
Hi Gaël,
The MSI displays this pop-up by default. We looked inside the MSI to try and remove the pop-up, but it didn't work.
If you'd like, you can report the issue to Schneider to see if they have a solution to make the installation completely silent.
As it stands, the package cannot be silently packaged.
February 7, 2025 - 12:00
Hello Gaël,
pending a response from Schneider on your end, I'm marking this topic as RESOLVED.
Regards,
