[RESOLVED] Request to display dmi audit data
Share your SQL query ideas for reporting in the WAPT Enterprise console here
psgca85
Registration: December 26, 2023 - 3:02 PM
March 14, 2025 - 4:49 PM
Since the upgrade to version 2.6, DMI data is no longer stored in the hosts table. It is retrieved using DMI auditing.
How can I retrieve this data using a query?.
For example, in version 2.5, to retrieve TPM information from PCs, it was enough to make this request.
SELECT
	    computer_name,
	    host_info -> 'tpm' AS tpm_infos
FROM
	    hosts
WHERE
   computer_name = 'nomdupc'
Thank you in advance.
Benoit.
March 17, 2025 - 09:47
Example to retrieve Vendor from BIOS_Information in the audit-dmi package
WITH cte AS (
    SELECT ctid,
           host_id,
           row_number() OVER (PARTITION BY host_id, value_key ORDER BY value_date) AS rank
    FROM HostAuditData
    WHERE value_section = 'audit-dmi' AND value_key = 'audit-dmi'
SELECT
    cte.host_id,
    h.computer_fqdn,
    had.value->'BIOS_Information'->'Vendor' as Vendor
FROM HostAuditData had
JOIN cte ON cte.ctid = had.ctid
JOIN hosts h ON h.uuid = cte.host_id
WHERE cte.rank = 1;
psgca85
March 17, 2025 - 10:49
Thank you for this answer, which I was able to adapt to my needs.
Benoit.
March 17, 2025 - 10:54
Hello Benoit,
feel free to post your version of the query as a reply in the forum; there are probably others besides you who will have the same question. :-)
- Denis
psgca85
March 17, 2025 - 10:59
Hello Denis,
Below is my query to find the TPM version.
WITH cte AS (
    SELECT ctid,
           host_id,
    FROM HostAuditData
SELECT
    cte.host_id,
    h.computer_fqdn,
    had.value->'TPM_Device'->'Specification_Version' as TPMVersion
WHERE cte.rank = 1;
Benoit.
March 17, 2025 - 2:36 PM
