Rustdesk Problem - Agent Configuration Deployment
Answer
pbodin
Registration: March 27, 2025 - 2:58 PM
March 27, 2025 - 3:16 PM
Hello everyone,
New to software deployment via Wapt; I would like to be able to deploy rustdesk with the configuration of the server ID, relay server, key and possibly the whitelist.
I tried to set up the Wapt template configuration for Rustdesk, following the topic viewtopic.php?t=4191.
However, when I get to the JSON configuration stage, I get an error status (see screenshot)
Full message:
CRITICAL:waptcore:Fatal error in update_package  NameError: name 'ID_YES' is not defined:
  File "C:\Program Files (x86)\wapt\common.py", line 8927, in call_python_code
    hookdata = hook_func()
  File "C:\Users\pbodin\AppData\Local\Temp\wapt\JObYSk9_\tav-rustdesk-config-template_14_PROD-wapt\setup.py", line 69, in update_package
    if is_json_config == ID_YES:
  File "C:\Program Files (x86)\wapt\common.py", line 8931, in call_python_code
    raise e
My version of Wapt: WAPTConsole Enterprise version 2.6.0.16937
2025-03-27 15_04_38-WAPTConsole Enterprise version 2.6.0.16937.png (182.61 KB) Viewed 6559 times
March 27, 2025 - 3:55 PM
Hello
, you are currently using version 14. A new version (version 25) is now available: https://wapt.tranquil.it/store/fr/tis-r ... g-template . It should fix this problem.
pbodin
March 27, 2025 - 5:21 PM
My bad :-) ... I updated the package and I was indeed able to add my custom information. I'll do a live test tomorrow.
Thanks for your quick reply.
And regarding whitelists, is there a way to incorporate them into the configuration as well?
March 28, 2025 - 11:26
Hi Philippe,
no worries, the local upgrade via the wapt console allows for 100% autonomy in updating packages, but it doesn't benefit from the patches released as the software evolves. :-)
Regarding the whitelist, we'll need to figure out how to configure it. If you know how, feel free to post it here; it might be helpful to others!
Best regards,
Answer
