Improvement - Batch removal of packages
Answer
town hall 30380
Registration: May 26, 2023 - 5:50 p.m.
April 16, 2025 - 4:19 PM
would it be possible to add to the WAPT console the ability to delete various older versions of packages in batches?
For example, to keep only the X (allowing the user to define the number of versions to keep) most recent packages for an application.
This would display a window containing a list of packages to be deleted, with pre-checked boxes so the user can deselect some and then confirm to start the deletion.
April 17, 2025 - 10:57
Hi Nicolas,
in the context menu of the private repository tab, you can choose "select obsolete packages." This pre-selects them in the list and allows you to deselect them if you want to keep some. However, there is no configuration option like "keep versions N and N-1."
The usability of this feature will be improved in a future version (development has been underway regarding this).
Best regards,
Answer
