[RESOLVED] Wapt TFTP Server
Emmanuel64
Registration: February 23, 2024 - 09:37
April 22, 2025 - 3:18 PM
Good morning
I activated wapttftpserver when testing the TFTP server as indicated in the documentation:
tftp server.wapt.local
tftp> binary
tftp> get ipxe.efi
Error code 1: File not found
So I tested it with tftpd-hpa as seen on the forum
systemctl stop wapttftpserver
systemctl disable wapttftpserver
apt-get install tftpd-hpa
then edit the /etc/default/tftpd-hpa file
TFTP_USERNAME="tftp"
TFTP_DIRECTORY="/var/www/wads/pxe
TFTP_ADDRESS="0.0.0.0:69"
TFTP_OPTIONS="--secure"
systemctl restart tftpd-hpa
And now the download works...
The follow-up question... In the wads file structure, I have, for example, ./pxe/EFI/Boot/bootmgfw.efi
I'm surprised to see these folders in uppercase (especially under Linux), and during boot, it's actually ./pxe/efi/boot/bootmgfw.efi (in lowercase) that's retrieved
I'm stuck on how to solve this problem; perhaps there's a way to "repair or reinstall" the WADs files
Thank you in advance for your help
WAPT Enterprise
Version 2.7.0.19593
Server OS: Debian Trixie
Administration machine OS: W11
April 24, 2025 - 11:54
Hello Emmanuel,
there has been a regression on the wapttftpserver under Linux (cf. viewtopic.php?t=4288This has been fixed internally and is available in the nightly builds, and will be available very soon with the next release. In the meantime, you can simply downgrade it by following the warning in the changelog [1]:
wget https://wapt.tranquil.it/wapt/releases/wapt-2.6.0.16937-7ba7ea7a/bin/linux-x64/wapttftpserver
mv wapttftpserver  /opt/wapt/wapttftpserver.bin
chmod a+x /opt/wapt/wapttftpserver.bin
systemctl restart wapttftpserver
Sorry for the inconvenience.
[1] https://www.wapt.fr/en/doc/wapt-changel ... 2025-04-09
Emmanuel64
April 24, 2025 - 12:16
Thanks dcardon!
I've looked into every possible angle (including firewall rules...). Good review of protocols and troubleshooting then! :D
But it's reassuring to know I'm not crazy. :P
It works, I'll continue my tests on WADs!
Thanks!
WAPT Enterprise
Version 2.7.0.19593
