[SOLVED] PuTTY packages and overly broad uninstallation
STbar
Registration: January 31, 2019 - 09:39
April 30, 2025 - 12:01
The PuTTY package uses the following code during installation to uninstall older versions:
    for to_uninstall in installed_softwares(name="PuTTY "):
        if Version(to_uninstall["version"]) < Version(control.get_software_version()) or force:
However, other products have the name PuTTY in their names.
This implies the unwanted uninstallation of other software.
I suggest you use the following code which checks the editor to avoid any problems:
        if to_uninstall["publisher"]=="Simon Tatham" and (Version(to_uninstall["version"]) < Version(control.get_software_version()) or force):
Good day
jlepiquet
Registration: Sep 3, 2024 - 4:09 p.m.
April 30, 2025 - 2:15 PM
Thank you for the feedback.
Indeed, that could have been a problem. We've added the publisher to the if statement as you recommended.
We've also modified the search name so that it starts with "PuTTY" and doesn't just contain it.
This should reduce the number of unexpected uninstallations.
The package is available here in pre-production: https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Have a good day
. Best regards,
