I'd like some information regarding the tis-withsecure-agent-desktop package.
I'm having trouble with the MSI parameters and how to integrate them into the package.
In setup.py, I modified it as follows:
properties={
"VOUCHER": "xxxx-xxxx-xxxx-xxxx-xxxx"
#"UNIQUE_SIGNUP_ID": "smbios"
Unfortunately, if I try to add another parameter, the installation fails after regenerating the package.
Can anyone help me with this? Thanks in advance,
Pierre
[RESOLVED] tis-with-secure-agent-desktop and MSI settings
pierre.briec
- Registration: June 2, 2025 - 10:42
Did you separate the "properties" with commas?
properties={
"VOUCHER": "xxxx-xxxx-xxxx-xxxx-xxxx",
}For WithSecure, I use a powershell script provided by WithSecure.
My package therefore only contains the InstallWithSecure_S1.ps1 file, and the installation from setup.py only contains the line:
Here is the content of the script (you just need to change the serial number).
run('Powershell -WindowStyle Hidden -ExecutionPolicy ByPass -File "InstallWithSecure_S1.ps1"')Code: Select all
Clear-Host
# ********** Variables
$dossierinstall = "c:\windows\temp\"
$CP = "installer"
$serie = "XXXX-XXXX-XXXX-XXXX-XXXX"
$valeur = (Get-ItemProperty -Path "HKLM:\SOFTWARE\MIcrosoft\Windows NT\CurrentVersion" -Name ProductName).ProductName
if ($valeur -like "*Server*") {
$fsecurecp = $dossierinstall + $CP + ".exe"
# ********** Verification deja installe
$WantFile1 = "C:\Program Files (x86)\F-Secure\PSB\fshoster32.exe"
$WantFile2 = "C:\Program Files\F-Secure\PSB\fshoster32.exe"
$FileExists1 = Test-Path $WantFile1
$FileExists2 = Test-Path $WantFile2
if ( $FileExists1 -eq $True ) { Exit }
if ( $FileExists2 -eq $True ) { Exit }
# ********** Telechargement
$FileExists = Test-Path $dossierinstall
If ($FileExists -eq $False) { New-Item -path $dossierinstall -ItemType directory }
$ChkFile = $fsecurecp
$FileExists = Test-Path $ChkFile
Invoke-WebRequest -Uri http://download.withsecure.com/PSB/latest/ElementsAgentInstaller.exe -OutFile "$fsecurecp"
# ********** D�sinstallation S1
$ProcessSA = Get-Process SentinelAgent -ErrorAction SilentlyContinue
if ($ProcessSA) {
#Check Administrator Privilege
$user = [Security.Principal.WindowsIdentity]::GetCurrent();
$admin=(New-Object Security.Principal.WindowsPrincipal $user).IsInRole([Security.Principal.WindowsBuiltinRole]::Administrator)
if ($admin -eq $false) {
"Please run the script as Administrator"
Start-Sleep -s 10
#Define the API Token
#To automate the script, get the API Token from management, enter it here, and save the script.
$token = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add("Authorization", "APIToken $token")
#where $token is your API token. For example, "APIToken abcdefg...."
#Gets Management URL
$config = & 'C:\Program Files\SentinelOne\Sentinel*\SentinelCtl.exe' config | select-string -Pattern "server.mgmtServer"
$mgmt = $config -split ' ' | select -last 1
#Gets passphrase for Endpoint
$uuid = & 'C:\Program Files\SentinelOne\Sentinel*\SentinelCtl.exe' agent_id
$passphrase_url = $mgmt + "/web/api/v2.1/agents/passphrases?uuids="+"$uuid"
$passphrase = (Invoke-RestMethod ("$passphrase_url") -Method 'GET' -Headers $headers).data.passphrase
#Start the Uninstallation
Write-Host "Starting Uninstallation Process..."
Write-Host "This Process may take a while. Please do not close the Window."
& 'C:\Program Files\SentinelOne\Sentinel*\uninstall.exe' /uninstall /norestart /q /k "$passphrase"
# ********** Install
$Command_line='"' + $fsecurecp + '"'
Start-Process -FilePath $Command_line -Wait -ArgumentList "--silent", "--voucher $serie", '--skip-sidegrade "*"'
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
- WAPT Expert
Hi Thomas,
that's funny, the script you published automatically uninstalls SentinelOne by retrieving the uninstallation password from the SentinelOne management server...
and it also downloads WithSecure if needed.
So basically, the provided WAPT package should do the trick if the VOUCHER value is correctly entered
. Regards,
. Regards,
