Mac client machine name
Answer
jjsoueix
Registration: July 31, 2018 - 4:50 PM
October 3, 2025 - 5:51 PM
We've identified that Macs are being identified by their DNS name, not their actual hostname, in the "Machine" field of the WAPT administration console.
This makes it difficult to identify the name of a Mac connected to a docking station or RJ45 dongle.
Do you have a solution or configuration to resolve this?
Thank you.
WAPT Enterprise Server Version: 2.6.0.17392
Server OS: RHEL10
October 6, 2025 - 9:34 AM
Good morning
I just took a quick look at how to retrieve the name on a Mac.
The following command is clearly being used:
/bin/hostname
To ask the pimp his name.
Can you see what that shows up on your end?
October 6, 2025 - 3:40 PM
Hello Jean-Jérôme,
The name of the Mac you want to have, are you retrieving it correctly with the hostname command?
Otherwise, do the following commands give results that are closer to what you want?
scutil --get ComputerName
scutil --get LocalHostName
Are the machines joined in a domain?
October 9, 2025 - 2:36 PM
Hello again Jean-Jérôme,
regarding the comment about the machine name depending on the MAC address (DHCP?), this bug existed in previous versions of WAPT, but it should no longer be the case in 2.6.
Regards,
Answer
