I just created a package for RAS Parallels, I tested the installation and uninstallation via pyscripter, without any problems.
Once the package is created, during deployment via wapt, the installation and auditing complete, but the software is not actually installed. Do you have any idea why?
In case you need it, the software installs in C:\Users\user\AppData\Roaming\ParallelsClient\
My package:
r"""
# Declaring local variables
# Installing the software
print("Installing: BL_RASClient.exe")
install_exe_if_needed('BL_RASClient.exe',
silentflags='/VERYSILENT /NORESTART',
key='',
min_version='20.2.25892'
def session_setup():
if not isdir(makepath('c:/Echanges')):
mkdirs('c:\\Echanges')
print('Uninstalling BL_RASClient')
uninstall_exe = makepath(user_appdata(), 'ParallelsClient', 'BasicClientInstaller.exe')
print('Using uninstaller:', uninstall_exe)
if isfile(uninstall_exe):
run(u'"{}" /verysilent'.format(uninstall_exe), timeout=300)
print('Desinstallateur introuvable : {}'.format(uninstall_exe))
remove_tree(r'c:\Echanges', ignore_errors=True)
