[RESOLVED] WADS image deployment issue since the 2.6.1.17654 update
Bruno78
Registration: June 19, 2024 - 11:40
January 28, 2026 - 5:01 PM
I am contacting you regarding a problem we've encountered on our WAPT platform since the update to version WAPT-2.6.1.17654 (January 19, 2026).
Since this update, image deployment via WADS no longer works on the machines. The workstation boots correctly in WinPE, but the network verification script consistently returns the message:
"– No Valid IP address found."
However, in a WinPE session, the `ipconfig /all` command indicates that no valid IP address is obtained.
I have also:
regenerated the WinPE image from the WAPT console,
added the machine-specific network drivers to WinPE, and
checked the configuration of the wapt-get.ini file (server URL, port, certificate verification parameters).
Despite these actions, the "No Valid IP address found" message persists and prevents wgetwads/wads.cmd from launching.
The server is running Debian GNU/Linux 11 (64-bit).
Thank you in advance for your help, and I remain available for any further information.
WADS.jpg error
WADS error.jpg (217.96 KB) Viewed 7326 times
January 28, 2026 - 5:48 PM
a version of WinPE (tis-wads-requirement-minimal-x64) was temporarily sent to the wapt.tranquil.it server (version 10.1.28000.1).
We have since removed it, as this version of WinPE (official Windows) apparently has issues with network drivers.
https://learn.microsoft.com/en-us/windo ... ember-2025
Check that you don't have version 10.1.28000.1 in your repository.
If so, remove the package and then force a reinstallation of tis-wads-requirement-minimal-x64 on your machine. The working version of WinPE is:
10.1.26100.2454.
Regenerate WinPE and it should be fine.
Bruno78
January 29, 2026 - 08:46
problem solved!
Thank you for your quick help!
Best regards
