[SOLVED] PB Signature WADS64.exe
t.heroult
Registration: December 8, 2020 - 10:13 AM
June 8, 2026 - 10:38
Good morning
After the console asked me to recreate WinPE, I get this message when starting the deployment.
Any idea what's wrong?
Consoles: Windows 10 & 11
Infrastructure: Windows
June 8, 2026 - 11:08
the sum of wads64.exe does not appear to be valid; the one signed by the key does not match (this sum is re-signed when the agent is generated).
You can also see this in the console under Tools > Sign the deployment file
https://www.wapt.fr/fr/doc-2.6/quicksta ... quirements
This allows you to verify that the executables provided by the server are valid.
t.heroult
June 8, 2026 - 12:04
Great, it worked!
Thank you so much :)
