Unable to save and apply packages since the Wapt server update
Answer
fcolson
Registration: June 11, 2026 - 3:06 PM
June 11, 2026 - 3:21 PM
We recently updated our WAPT server from version 2.6.1.17576 to version 2.6.1.17787.
Once the server was updated, I installed the new WAPT console and generated a new agent. However, when I install the new WAPT agent on computers, I am unable to save and apply the added packages to the machine in the WAPT console; the option is grayed out.
We are using a WAPT Discovery server on a Windows Server 2025.
Florian Colson
June 11, 2026 - 5:45 PM
Hi Florian,
if these buttons are grayed out, it means you don't have a key/certificate in the console that matches the one deployed on the workstations. You just need to retrieve the correct key/certificate and configure it in the console.
Regards,
Answer
