Request for an SVN/Git tutorial with PyScripter
cdeze
Registration: Nov 29, 2016 - 09:39
March 7, 2017 - 10:37
is there any documentation or tutorial for version control for packages using PyScripter?
I'd like to have a single Git/SVN repository for all packages,
and also not have the executable files in the repository.
Thank you.
Floflobel
Registration: Oct 15, 2015 - 5:32 p.m.
March 7, 2017 - 11:07
You can use Git to manage your repository.
I recommend exporting the .exe files to an FTP server that can handle the download load.
Then use the wget function (https://dev.tranquil.it/sphinxdocs/sour ... lpers.wget) to download the .exe file. You can store the .exe files in the Windows temporary folder until the installation is complete, then delete them.
Feel free to ask if you need any further assistance.
cdeze
March 20, 2017 - 12:02
Frankly, the way to make SVN or Git work with the `sources` parameter isn't very clear.
I've correctly entered the address of my SVN or Git repository, but it's not working.
Command Line: `-ldebug sources C:\wapt\dev\dsi-joineole-wapt\WAPT
FATAL ERROR: Exception: No sources defined in package control file and no default_sources_url in config file
File "C:\wapt\wapt-get.py", line 1106, in`
main()
File "C:\wapt\wapt-get.py", line 655, in main
os.startfile(mywapt.get_sources(args[1]))
File "C:\wapt\common.py", line 3518, in get_sources
raise Exception('No sources defined in package control file and no default_sources_url in config file')
Floflobel
March 20, 2017 - 1:57 PM
could you please send me your complete package? It seems some information is missing from a file (control).
SVN and Git are not linked to WAPT; you need to set them up yourself and then commit using Git. Please note that compiling with WAPT does not automatically link you to Git or SVN.
cdeze
March 20, 2017 - 3:35 PM
Yes, we have an SVN repository that is ready http://svn.XXXXXXXX.fr/svn/104-wapt-packages
The files are quite simple.
package           : dsi-joineole
version           : 1.1-3
architecture      : all
section           : base
priority          : optional
maintainer        : cdeze
description       : automatic package for joineole
depends           :
conflicts         :
sources           : http://svn.XXXXXXXX.fr/svn/104-wapt-packages
installed_size    :
signer            : wapt-etab.XXXXXXX.fr
signer_fingerprint: XXXXXXXXXXXXXXXXXXX
min_wapt_version  :
maturity          :
locale            :
uninstallkey = ['joineole']
# command(s) to launch to remove the application(s)
uninstallstring = []
    print('installing joineole')
    if os.path.isfile('c:/joineole.exe'):
        os.unlink('c:/joineole.exe')
    filecopyto('joineole.exe','c:/')
    print "Registering uninstall"
    register_uninstall('joineole','c:\\wapt\\wapt-get.exe uninstall dsi-joineole',False,quiet_uninstall_string='',
        install_location = None,display_name='joineole',
        display_version = None,publisher = 'Education Nationale')
    print "Remove joineole"
    remove_file('c:/joineole.exe')
    remove_file('c:/joinlog.log')
    unregister_uninstall('joineole',False)
    print "Uninstall successsful"
