[RESOLVED] Console tab navigation freezes after update 2.6.1.17870
esberard
Registration: Oct 09, 2023 - 11:35
September 9, 2026 - 8:43 AM
We have just updated to the latest stable version (2.6.1.17870) and we are experiencing a lot of console freezes when trying to move between the different tabs (Inventory, Private Repository, Windows Update...).
Exporting a machine to the OS deployment also freezes the console for 1 minute.
The problem occurs when the driver list is updated; it freezes the console, and the server's "wapt" and "www-data" processes consume a significant amount of resources. We currently have 213 entries in the driver section.
"GET /api/v3/get_driver_bundle_names HTTP/1.1" 200 18395356 "-" "waptconsole/2.6.1.17870A"
This also occurs when refreshing the list of Windows updates in WUA.
"GET /api/v3/windows_updates HTTP/1.1" 200 6904386 "-" "waptconsole/2.6.1.17870A"
Thank you for your feedback.
Remy
esberard
September 9, 2026 - 9:46 AM
September 9, 2026 - 3:59 PM
Discussed with Rémy:
- For Windows updates, one KB in particular (Silverlight update) has a very large list of URLs (10MB) and significantly slows down loading => delete this KB from the server's database.
- For driver bundles, the console code in version 2.6 unnecessarily loads the entire server content into the grid (list of files/hashes for each driver pack). Backporting the server code for the get_driver_bundle_names endpoint from version 2.7 resolves the issue.
esberard
September 15, 2026 - 11:42
Hi Hubert,
Could you paste the command you used to remove the KB from the server here?
Thanks
, Rémy
September 15, 2026 - 6:53 PM
Good evening,
You need to identify Windows updates that have an excessively large download_urls column
on the server:
sudo -u wapt psql
select update_id,title,pg_column_size(download_urls) from wsusupdates where pg_column_size(download_urls)>10000;
then erase
delete from wsusupdates where update_id=' 7f8b9228-75de-4b5a-80........';
