WAPTDEPLOY.EXE deployment error via GPO
alxinfo
Registration: Apr 07, 2017 - 5:16 p.m.
April 7, 2017 - 5:18 PM
After following the documentation I created the GPO but the script is encountering a problem with the following error code (see attachment).
agauvrit
Registration: Nov 17, 2016 - 10:25
April 7, 2017 - 5:53 PM
As stated in the documentation, WAPT Deploy expects a checksum, a hash, to verify the integrity of waptagent.exe which it will have to download and execute.
Therefore, your command line becomes:
waptdeploy.exe --hash=70d90ca28d89052b0492b76e021c3dda13daedff --minversion=1.3.8 --wait=15
That should work better.
You can test this manually using the command line. Also, is your call to waptdeploy.exe correctly using a network UNC path? (e.g., \\server\scripts\waptdeploy.exe)
The documentation for waptdeploy can be found here: https://wapt.fr/fr/doc/Installation/wap ... waptdeploy
Good deployment!
Alexander
alxinfo
April 9, 2017 - 7:55 PM
Good evening,
thank you for your quick reply. However, I followed the tutorial in the documentation to the letter. I'll try again tomorrow with your order, we'll see how it goes.
Thanks again and have a good evening.
alxinfo
April 10, 2017 - 8:57 AM
I made the changes indicated, and now I get the following feedback:
agauvrit
April 10, 2017 - 9:46 AM
Just a quick note: the hash is different for each generated agent !
You need to retrieve the hash displayed in your WAPT server's web interface.
That should work much better.
alxinfo
April 10, 2017 - 9:52 AM
I just restarted the hash process as indicated in my documentation (something I did the first time) and here's the result:
For your information, here is the hash I have on my deployment server (it is not the same as the domain controller server, does that change anything?).
agauvrit
April 10, 2017 - 10:30
Is the WAPT server reachable at the following address: http://wapt.ot.local/wapt/ ?
waptdeploy.exe simply goes and downloads waptagent.exe from the wapt server specified in the DNS fields, in this case "http://wapt.ot.local/wapt/waptagent.exe", then checks with the hash that the file signature matches and launches the silent installation of the agent.
The exception obtained means that no waptagent.exe file is downloaded.
To force the download from the WAPT server's IP address, use the following command:
waptdeploy.exe --hash=<.....> --minversion=1.3.8 --wait=15 --waptsetupurl="http://ip_serveur/wapt/waptagent.exe"
In addition, waptdeploy.exe is independent of any domain controller/Active Directory, it only serves as a "wrapper" and allows the automatic download of the WAPT agent and launches its installation silently.
PS: In case you need it, the DNS configuration is explained here: https://www.wapt.fr/fr/doc/Installation ... n_dns.html
We're almost there!
alxinfo
April 10, 2017 - 10:39
So the server absolutely has to be called wapt?
That would explain why. My server is srv-deploy.
I'll try renaming it. I'll keep you posted.
alxinfo
April 10, 2017 - 11:26
Good,
I have access, it works (small firewall error and server name corrected) but I still have another problem....(I'm such a klutz you'll say ^^).
alxinfo
April 10, 2017 - 12:16
Hello again,
I think I've found the problem. I installed it on an IP range like 192.168.21.** and when I use waptdeploy (after changing the workstation's IP address), the configuration that's sent to the PCs on the network is still using the original IP address (192.168.21.**). However, if I manually install the agent using the correct IP address, it works.
Is there a way to change the IP address in the configuration file, or do I need to reinstall the application on the server?
Thanks in advance.
