Uninstalling the package
Killian
Registration: May 3, 2017 - 11:19
May 9, 2017 - 09:07
I created a package but I can't uninstall it
Here is my code:
    print('installing Smaps')
    install_exe_if_needed("smapS_Installation_2.7.0.0.exe",'/VERYSILENT /SUPPRESSMSGBOXES /NORESTART',key='',min_version='0.0.0.0')
May 10, 2017 - 2:07 PM
Killian
May 10, 2017 - 2:08 PM
Entering one doesn't change anything, and when I use `print uninstallkey`, no key is displayed
May 10, 2017 - 3:12 PM
In this case, it might mean that the uninstall key for the software you are using is not working.
Refer again to the documentation:
https://www.wapt.fr/fr/doc/CreationPaqu ... stallation
