Office 2016
waptoffice
Registration: May 19, 2017 - 2:30 p.m.
May 19, 2017 - 2:44 PM
i am having trouble creating office pro plus 2016 package. I have followed the instructions on reseaux85:
- Copy Office CD to folder
- run setup.exe /admin within office folder
- create template "wapt-get make-template setup.exe"
- i replace contents of setup.py from newly created wapt-package folder
- i copy contents of office folder to root of wapt-package folder
- build and upload: " Wapt-get build-upload<wapt-package folder> "
when i add it to a host, it fails every time with a not very helpful:
"error during install of<package> : errors in packages<package> "
can you provide some help? thank you
setup.py:
    def uninstall_office_modules():
        print('Suppression des anciens modules office..')
        check_installed_soft = installed_softwares('Microsoft Office System')
        if check_installed_soft:
                key=uninstall['key']
                if installed_softwares(uninstallkey=key):
                    run(cmd)
    def uninstall_office365():
        print('Suppression Office 365')
        check_installed_soft = installed_softwares('office 365')
                    run(cmd)
    def killsoft():
      for soft in ('WINWORD.EXE','POWERPNT.EXE','EXCEL.exe','MSPUB.EXE','MSACCESS.EXE','INFOPATH.EXE','lync.exe','ONENOTE.EXE','OUTLOOK.EXE','ONENOTEM.EXE','MSOSYNC.EXE','GROOVE.EXE'):
        if isrunning(soft):
           print ("closing %s" % soft)
           killalltasks(soft)
    softname = 'Microsoft Office Professionnel Plus 2016'
    check_installed_out = installed_softwares(softname)
    print('installing Office 2016')
    if not check_installed_out:
            cmd = '"setup.exe" /adminfile "silent.msp"'
            cmd = 'msiexec.exe /p silent.msp'
    killsoft()
        error('End audit did not find the software.')
    fichier = open("%s\silent.xml" % programfiles32, "w" )
    fichier.write('<Configuration Product="ProPlus"> \n')
    fichier.write('<Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" /> \n')
    fichier.write('   <Setting Id="SETUP_REBOOT" Value="NEVER" /> \n')
    fichier.write('</Configuration> \n')
    fichier.close()
    run('"%s\Common Files\microsoft shared\OFFICE16\Office Setup Controller\Setup.exe" /uninstall ProPlus /config "%s\silent.xml"' % (programfiles32,programfiles32),timeout=1200)
    remove_file(r'%s\silent.xml'% programfiles32)
agauvrit
Registration: Nov 17, 2016 - 10:25
May 19, 2017 - 3:47 PM
Hi,
Are you using PyScripter for package development?
Are you deploying Microsoft Office Professional Plus 2016? Standard ?
PyScripter is available in package bundle tis-waptdev, you'll be able to debug your package and have a better feedback.
Your source code seems fine, please try to launch the install function using PyScripter and maybe you'll have an explicit error code.
Alexander
waptoffice
May 23, 2017 - 09:27
i have downloaded the package and imported to my wapt server/repository
(by the way, when I try to "import from internet" it fails with:
download canceled.: "" is an invalid integer
after i add it to the client, it says:
result: {"skipped": [["waptdev....
after the install of office package still fails
May 23, 2017 - 2:04 PM
waptoffice wrote:i have downloaded the package and imported to my wapt server/repository
This error message often appears when the proxy in the console is incorrectly configured
https://www.wapt.fr/en/doc/Utilisation/ ... et-basique
waptoffice wrote: )
This means that the waptdev package is already installed!
waptoffice wrote: after the install of office package still fails
Can you give us the error of the office package?
In the console, click on the computer, in the right part click on the package in error.
https://www.wapt.fr/en/doc/Utilisation/ ... et-general
waptoffice
May 23, 2017 - 2:29 PM
thank you for your help, i see it installed ;)
the error for office is:
installing office 2016
Removing old office modules
deletion office 265
CalledProcessError: Command
'("setup.exe /adminfile "silent.msp"",)' returned non-zero exit status 30059
i see this is related to office license key? ill check it again, im sure its correct.
waptoffice
May 24, 2017 - 10:44
i removed the key from the silent.msp and it works perfectly now
thank you
