I've been trying for several days to create a package for Microsoft Teams, but when I run `build-upload`, the .exe file launches on my machine. This is the first time this has happened.
Furthermore, when I try to deploy it to the client machine, there are no error messages. According to the logs, Teams is installed, but I see nothing.
The .exe file is from the Microsoft website. I've tried both the 32-bit and 64-bit versions, but
Here is my setup.py:
print('installing wapt-teams64')
run(r'"Teams_windows.exe" ')
I've tried with /VERYSILENT, then with -s, and with nothing, but still nothing.
It's important to note that this is a machine with a user account that doesn't have admin privileges; all other packages work (Skype, Skype for Business, Chrome, etc.).
Manual installation works fine; the user has a valid license.
In short, the installation is successful, but there's no trace of the software on the PC.
Client machine OS: Windows 7 Pro x64.
Any ideas?
Thanks.
Microsoft Teams impossible to install
Microsoft Teams is software that installs in the user profile (in AppData), therefore it's not possible to install it permanently on a computer, as with most software that installs in Program Files.
Your installation was actually performed under a system account (the WAPT service runs under a system account) and nothing appears because it's outside the user's access.
To work around this problem, install this software in the user context using the session_setup feature (see https://doc.wapt.fr ).
For information on the silent arguments of Microsoft Teams: https://techcommunity.microsoft.com/t5/...td-p/32469
Hoping this helps!
Alexandre
Hoping this helps!
Alexandre
Thanks for the reply.
Well, I understand better now; I did notice the %appdata%.
I've tried several things, but I can't find a solution.
The documentation doesn't offer anything except for creating a shortcut.
As a last resort, I tried this, but still nothing (I expected that ^^):
install_exe_if_needed("Teams.exe")
def session_setup():
install_exe_if_needed("Teams.exe" /VERYSILENT)
- WAPT Expert
With session_setup, it is not possible to call files contained in the package.
To use files during uninstallation, copy/paste the files into a directory outside the package during package installation.
https://www.wapt.fr/fr/doc/CreationPaqu ... sion-setup
Note that the session setup is only executed when the session starts!
filecopyto("Teams_windows.exe",programfiles)
run(r'"%s/Teams_windows.exe" /VERYSILENT' % programfiles )
