is it normal that the WAPT agent and WAPTsetup (which is intended for the administrator) are exactly the same? I just checked their MD5 and SHA1 hashes, and they are identical.
I suspect I made a mistake during the WAPT configuration, but I don't know when it happened.
Do you have any advice?
Are Agent WAPT and WAPTsetup exactly the same?
- WAPT Expert
Good evening Percherie,
no, that's definitely not normal. We had a bug on a version of WAPT under Linux where the file /var/www/wapt/waptsetup-tis.exe was replaced by a symbolic link pointing to /var/www/wapt/waptagent.exe. Could you check if this is the case on your installation, and tell us which version of WAPT you are using, and if you have upgraded, from which version?
