[SOLVED] Local WAPT Console Configuration
Vvarfendel
Registration: December 5, 2017 - 2:03 PM
December 5, 2017 - 2:07 PM
Following a CentOS server update (Yum Update), I no longer have access to my local console. The following issue is showing up in the troubleshooting section:
https://www.hostingpics.net/viewer.php? ... 4h0030.png
Does anyone have any ideas on what to investigate?
Regards,
Vvarfendel
fred74
Registration: February 2, 2016 - 10:42
December 6, 2017 - 10:03 AM
The CentOS firewall is a lead worth exploring...
Vvarfendel
December 6, 2017 - 11:51
my server's firewall is disabled, but the verification failed. I keep getting the same message.
fred74
December 6, 2017 - 1:55 PM
Apache's HTTPS seems to be the only thing causing the problem... Check your Apache configuration...
Have you installed Webmin for managing your server? It's quite useful and provides a more visual overview.
Vvarfendel
December 7, 2017 - 1:04 PM
I restarted the script: /opt/wapt/waptserver/scripts/postconf.py
Everything is working correctly. :D
Thank you anyway for addressing my issue.
fred74
December 7, 2017 - 1:20 PM
Cool, I'll see if that can solve my problem!
