[BETA] WAPT 1.5
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
December 11, 2017 - 5:00 PM
guigeek wrote: Dec 11, 2017 - 09:58
guigeek wrote: Dec 6, 2017 - 10:20 AM Thank you,
I ran `wapt-get register` in debug mode and everything went smoothly. It says "success." But on the server side, I still don't have the UUID.wapt...
Apparently, following a server update, the problem seems to be resolved...
Or not...
In fact, other clients installed behind it are experiencing the same problem... :(
guigeek
December 12, 2017 - 7:42 PM
I feel alone on this thread... :(
December 12, 2017 - 10:19 PM
Is your problem still the missing UUID.wapt file?
If so, that's normal; the message will appear as long as the machine package isn't created (from the console).
What are the remaining problems?
guigeek
December 13, 2017 - 8:36 AM
I found the problem with the websockets... it was due to the server having a completely different time compared to the clients!
However, I have a problem with the create_user_desktop_shortcut function in one of my wapt packages in the session-setup part which causes me the following error:
2017-12-13 08:29:14,720 DEBUG Change current directory to C:\Users\adminstm.
2017-12-13 08:29:14,720 DEBUG DB rollback
2017-12-13 08:29:14,723 DEBUG Error at DB exit (-2147024809, 'Incorrect parameter.', None, None), rollbacking
[' File "C:\\Program Files (x86)\wapt\common.py", line 5019, in session_setup\n raise e\n']
2017-12-13 08:29:14,726 CRITICAL com_error: (-2147024809, 'Param\xe8be incorrect.', None, None)
Any ideas?
December 13, 2017 - 2:43 PM
Synchronizing clocks between machines becomes more critical with this version of Wapt, because actions or the connection of the client to the server are signed, with a timestamp to avoid potential replay attacks.
guigeek
December 15, 2017 - 12:22 AM
Hi,
I still have 2 issues with version 1.5!
The issue I mentioned previously:
2017-12-13 08:29:14,723 DEBUG Error at DB exit (-2147024809, 'Param\xe8tre incorrect.', None, None), rollbacking
[' File "C:\\Program Files (x86)\\wapt\\common.py", line 5019, in session_setup\n raise e\n']
2017-12-13 08:29:14,726 CRITICAL com_error: (-2147024809, 'Param\xe8tre incorrect.', None, None)
package that worked in 1.3
And we have an ESET antivirus that detects the nssm.exe file as a potentially dangerous application and deletes it. :(
That's all for the feedback!
December 15, 2017 - 9:55 AM
Hello
, nssm is a third-party application: https://nssm.cc/
The executable is not resigned by us, see the conversation:
https://lists.tranquil.it/pipermail/wap ... 02417.html
I'm looking into the create_user_desktop_shortcut.
December 15, 2017 - 1:57 PM
I can't reproduce the bug for create_user_desktop_shortcut. Are you sure the problem is with BETA 1.5?
January 3, 2018 - 11:05 AM
For your information, we have just released the nightly version 1.5.1.13:
Two new features in this version:
- Passwords no longer appear in plain text during a build-up from PyScripter.
- We have ensured that the console works correctly with WineHQ (2.0.3) under Linux.
agauvrit
Registration: Nov 17, 2016 - 10:25
January 5, 2018 - 11:33
Good morning
