I need to run a PowerShell script from a package (to remove unnecessary apps from Windows 10 after an upgrade).
I've found several forum posts about this, but they all handle it differently!
Is there a cleaner solution?
For your information:
- WAPT version installed: 1.3.13
- Server OS: Debian Jessie
Thank you
[SOLVED] How to run a PowerShell script?
olaplanche
- Registration: January 26, 2017 - 11:11
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
- WAPT Expert
use the run_powershell function
For example :
It's the cleanest
For example :
run_powershell('Get-AppxPackage -Name Microsoft.Windows.Cortana -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}')-
olaplanche
Hello and thank you for the reply.
I am currently testing with the following package:
Only the middle command seems to work (no issues with a new user account). I can't find anything about the `run_powershell` function; is it possible to get feedback like in the PowerShell console? The Wapt console isn't reporting any errors, yet the apps aren't being removed from the administrator account!
THANKS
run_powershell('Get-AppXPackage -User Administrateur | where-object {$_.name –notlike “*store*”} | Remove-AppxPackage')
run_powershell('Get-appxprovisionedpackage –online | where-object {$_.packagename –notlike “*store*”} | Remove-AppxProvisionedPackage -online')
run_powershell('Get-AppxPackage -AllUsers | where-object {$_.name –notlike “*store*”} | Remove-AppxPackage')THANKS
olaplanche
Additional information:
I am using the x64 version of powershell and this could be due to limitations of it for the system account.
olaplanche
I'm bringing this problem up again, as I still haven't solved it.
Quite a few things have changed in the meantime, namely:
- Installed WAPT version: 1.6.2.7
- Server OS: Debian Stetch
- Operating system of the administration/package creation machine: Windows 10
Next, I use a new script during my MDT deployment; here it is:
I would like to use it in a wapt package, but I don't see how...
Can someone point me in the right direction?
THANKS
# Functions
function Write-LogEntry {
param(
[parameter(Mandatory=$true, HelpMessage="Value added to the RemovedApps.log file.")]
[ValidateNotNullOrEmpty()]
[string]$Value,
[parameter(Mandatory=$false, HelpMessage="Name of the log file that the entry will written to.")]
[string]$FileName = "RemovedApps.log"
# Determine log file location
$LogFilePath = Join-Path -Path $env:windir -ChildPath "Temp\$($FileName)"
# Add value to log file
try {
Add-Content -Value $Value -LiteralPath $LogFilePath -ErrorAction Stop
catch [System.Exception] {
Write-Warning -Message "Unable to append log entry to RemovedApps.log file"
# Get a list of all apps
Write-LogEntry -Value "Starting built-in AppxPackage and AppxProvisioningPackage removal process"
$AppArrayList = Get-AppxPackage -PackageTypeFilter Bundle -AllUsers | Select-Object -Property Name, PackageFullName | Sort-Object -Property Name
# White list of appx packages to keep installed
$WhiteListedApps = @(
"Microsoft.DesktopAppInstaller",
"Microsoft.WindowsCalculator",
"Microsoft.WindowsStore"
# Loop through the list of appx packages
foreach ($App in $AppArrayList) {
# If application name not in appx package white list, remove AppxPackage and AppxProvisioningPackage
if (($App.Name -in $WhiteListedApps)) {
Write-LogEntry -Value "Skipping excluded application package: $($App.Name)"
else {
# Gather package names
$AppPackageFullName = Get-AppxPackage -Name $App.Name | Select-Object -ExpandProperty PackageFullName
$AppProvisioningPackageName = Get-AppxProvisionedPackage -Online | Where-Object { $_.DisplayName -like $App.Name } | Select-Object -ExpandProperty PackageName
# Attempt to remove AppxPackage
if ($AppPackageFullName -ne $null) {
try {
Write-LogEntry -Value "Removing application package: $($App.Name)"
Remove-AppxPackage -Package $AppPackageFullName -ErrorAction Stop | Out-Null
Write-LogEntry -Value "Removing AppxPackage failed: $($_.Exception.Message)"
else {
Write-LogEntry -Value "Unable to locate AppxPackage for app: $($App.Name)"
# Attempt to remove AppxProvisioningPackage
if ($AppProvisioningPackageName -ne $null) {
try {
Write-LogEntry -Value "Removing application provisioning package: $($AppProvisioningPackageName)"
Remove-AppxProvisionedPackage -PackageName $AppProvisioningPackageName -Online -ErrorAction Stop | Out-Null
Write-LogEntry -Value "Removing AppxProvisioningPackage failed: $($_.Exception.Message)"
else {
Write-LogEntry -Value "Unable to locate AppxProvisioningPackage for app: $($App.Name)"
# White list of Features On Demand V2 packages
Write-LogEntry -Value "Starting Features on Demand V2 removal process"
$WhiteListOnDemand = "NetFX3|Language|Browser.InternetExplorer"
# Get Features On Demand that should be removed
$OnDemandFeatures = Get-WindowsCapability -Online | Where-Object { $_.Name -notmatch $WhiteListOnDemand -and $_.State -like "Installed"} | Select-Object -ExpandProperty Name
foreach ($Feature in $OnDemandFeatures) {
try {
Write-LogEntry -Value "Removing Feature on Demand V2 package: $($Feature)"
Get-WindowsCapability -Online -ErrorAction Stop | Where-Object { $_.Name -like $Feature } | Remove-WindowsCapability -Online -ErrorAction Stop | Out-Null
Write-LogEntry -Value "Removing Feature on Demand V2 package failed: $($_.Exception.Message)"
# Complete
Write-LogEntry -Value "Completed built-in AppxPackage and AppxProvisioningPackage removal process"Can someone point me in the right direction?
THANKS
olaplanche
I solved my problem with the following code:
You need to enable PowerShell script execution on the affected machines or add the "-executionpolicy bypass" parameter
#import subprocess
run('powershell.exe -NoProfile -NonInteractive -File RemoveBuiltinApps.ps1')- Installed WAPT version: 2.6.0.16795 Enterprise
jeancharles
- Registration: June 11, 2019 - 10:02
A bit late, but wouldn't it be better to modify the powershell command to add "-executionpolicy bypass" directly into the command?
olaplanche
That's exactly what I indicated in my sentence
You need to enable PowerShell script execution on the affected machines or add the "-executionpolicy bypass" parameter.
jeancharles
Ah yes, indeed, reading about it, that's it,
I'm trying to go too fast and I'm forgetting half the information along the way!
Thank you!
Thank you!
