Problem installing dcsamba4 on an existing Windows AD domain
Come here to share your tips and tricks for using Samba4
eckeagle
Registration: December 27, 2017 - 5:39 PM
December 27, 2017 - 5:55 PM
Good morning
I have an Active Directory domain running on Windows Server 2012 R2, so the forest functional level is on Windows Server 2008 and the domain functional level is on Windows Server 2008 R2
I followed your tutorial https://dev.tranquil.it/wiki/SAMBA_-_In ... secondary To add a Debian 9 Samba 4 DC at the time of joining, it gives me these:
Adding 1 remote DNS records for ECKBADEB.kenneagle.lan
Adding DNS A record ECKBADEB.kenneagle.lan for IPv4 IP: 192.168.100.3
Join failed - cleaning up
Deleted CN=RID Set,CN=ECKBADEB,OU=Domain Controllers,DC=kenneagle,DC=lan
Deleted CN=ECKBADEB,OU=Domain Controllers,DC=kenneagle,DC=lan
Deleted CN=NTDS Settings,CN=ECKBADEB,CN=Servers,CN=Premier-Site-par-defaut,CN=Sites,CN=Configuration,DC=kenneagle,DC=lan
Deleted CN=ECKBADEB,CN=Servers,CN=Premier-Site-par-defaut,CN=Sites,CN=Configuration,DC=kenneagle,DC=lan
ERROR(runtime): uncaught exception - (9003, 'WERR_DNS_ERROR_RCODE_NAME_ERROR')
  File "/usr/lib/python2.7/dist-packages/samba/netcmd/__init__.py", line 176, in _run
    return self.run(*args, **kwargs)
  File "/usr/lib/python2.7/dist-packages/samba/netcmd/domain.py", line 661, in run
    machinepass=machinepass, use_ntvfs=use_ntvfs, dns_backend=dns_backend)
  File "/usr/lib/python2.7/dist-packages/samba/join.py", line 1474, in join_DC
    ctx.do_join()
  File "/usr/lib/python2.7/dist-packages/samba/join.py", line 1384, in do_join
    ctx.join_add_dns_records()
  File "/usr/lib/python2.7/dist-packages/samba/join.py", line 1116, in join_add_dns_records
    dns_partition=domaindns_zone_dn)
  File "/usr/lib/python2.7/dist-packages/samba/samdb.py", line 939, in dns_lookup
    dns_partition=dns_partition)
Can you help me, thank you in advance?
eckeagle
December 28, 2017 - 12:12
Good morning
After retesting, I managed to connect my Samba4 domain controller to my existing Active Directory domain
The directory is replicated correctly, but not DNS and sysvol:
for dns
root@eckbadeb:/home/nicoket# samba_dnsupdate --use-samba-tool --rpc-server-ip=192.168.1.78
ERROR(runtime): uncaught exception - (-1073741790, '{Access Denied} A process has requested access to an object but has not been granted those access rights.')
  File "/usr/lib/python2.7/dist-packages/samba/netcmd/dns.py", line 935, in run
    0, server, zone, name, add_rec_buf, None)
Failed update of 24 entries
samba-tool ntacl sysvolcheck ERROR(<type 'exceptions.TypeError'>): uncaught exception - (2, 'No such file or directory')
  File "/usr/lib/python2.7/dist-packages/samba/netcmd/ntacl.py", line 270, in run
    lp)
  File "/usr/lib/python2.7/dist-packages/samba/provision/__init__.py", line 1723, in checksysvolacl
    direct_db_access)
  File "/usr/lib/python2.7/dist-packages/samba/provision/__init__.py", line 1659, in check_gpos_acl
    direct_db_access=direct_db_access, service=SYSVOL_SERVICE)
  File "/usr/lib/python2.7/dist-packages/samba/ntacls.py", line 81, in getntacl
    xattr.XATTR_NTACL_NAME)
root@eckbadeb:/home/nicoket# samba-tool ntacl sysvolresetopen: error=2 (No such file or directory)
ERROR(runtime): uncaught exception - (-1073741823, '{Operation Failed} The requested operation was unsuccessful.')
  File "/usr/lib/python2.7/dist-packages/samba/netcmd/ntacl.py", line 239, in run
    lp, use_ntvfs=use_ntvfs)
  File "/usr/lib/python2.7/dist-packages/samba/provision/__init__.py", line 1609, in setsysvolacl
    set_gpos_acl(sysvol, dnsdomain, domainsid, domaindn, samdb, lp, use_ntvfs, passdb=s4_passdb)
  File "/usr/lib/python2.7/dist-packages/samba/provision/__init__.py", line 1502, in set_gpos_acl
    use_ntvfs=use_ntvfs, skip_invalid_chown=True, passdb=passdb, service=SYSVOL_SERVICE)
  File "/usr/lib/python2.7/dist-packages/samba/ntacls.py", line 162, in setntacl
    smbd.set_nt_acl(file, security.SECINFO_OWNER | security.SECINFO_GROUP | security.SECINFO_DACL | security.SECINFO_SACL, sd, service=service)
Does anyone have any ideas?
December 29, 2017 - 11:45 AM
The sysvol part is normal.
https://dev.tranquil.it/wiki/SAMBA_-_R% ... age_SYSVOL
With a Syncthing solution on both the Windows and Linux sides, it's certainly doable, but it will require some adjustments!
Regarding DNS, could you specify the IP address of the Windows Active Directory and the Samba 4 server?
eckeagle
January 2, 2018 - 5:57 PM
thank you for your reply.
The sysvol problem is understood and resolved.
Regarding DNS,
my Windows server is on IP address 192.168.1.78 and
my Linux server is on IP address 192.168.100.3.
After further testing, I completely rebuilt the server.
The connection only works if the option "To all servers running on domain controllers in this domain: mydomain.lan" is checked. Is this a server problem?
And DNS synchronization still doesn't work.
January 15, 2018 - 1:21 PM
eckeagle wrote: Dec 27, 2017 - 5:55 PM Hello,
I have an AD domain running on Windows Server 2012 R2, so the forest functional level is on Windows Server 2008 and the domain functional level is on Windows Server 2008 R2.
I followed your tutorial https://dev.tranquil.it/wiki/SAMBA_-_In ... secondary to add a Debian 9 Samba4 DC, but during the join process, it gives me these results:
Even though the forest level is 2k8r2, the Win2k12 server adds specific features that aren't compatible with Samba-AD (at least that was true 5-6 months ago). There have been commits posted to the mailing list to resolve this issue and add support for 2k12 schemas (I'm referring to schemas here, not silo functions, FAST, etc.).
It is better to do the test with a win2k8r2, or wait for Samba 4.8 which should probably include these improvements.
January 15, 2018 - 1:27 PM
eckeagle wrote: January 2, 2018 - 5:57 PM For DNS,
my Windows server is on IP 192.168.1.78
and my Linux server is on IP 192.168.100.3.
The connection only works if the option "to all servers running on domain controllers in this domain: mydomain.lan" is checked. Server problem???
I just joined a Windows Server 2008 R2 Active Directory to my Samba-AD domain running version 4.7.4. I'm having a problem replicating DNS zones (in fact, the KCC didn't even create the corresponding `repsfrom` and `repsto` records). It must be a regression, or there's something wrong with my `DC=DomainDNSZones` and `DC=ForestDNSZones` partitions. The other partitions are working fine... It's worked in the past, although mixed Samba/MS domains aren't recommended. I'll take another look this afternoon if I have time.
eckeagle
January 15, 2018 - 11:19 PM
I was starting to suspect it was coming from Network Manager. Yes, I installed the GNOME interface, but I don't know what to recommend
