Visibility of a group in the self-service portal
hasop
Registration: December 13, 2017 - 10:31
December 29, 2017 - 11:28
is it possible to make a group "restricted" like you can for a package?
I'd like to define a group of packages that are installed by default on my machines, and I don't want it to be visible in the self-service interface.
Thanks in advance.
WAPT 1.5.1.9
Server: CentOS 7
Administration: Windows 7 Pro
Clients: Windows 7 Pro
December 29, 2017 - 11:41
Hmm, to put it simply, no.
But you can very well create a package with dependencies (which therefore behaves like a group package) and put it in restricted mode.
hasop
December 29, 2017 - 12:02 PM
Yes, that's one solution.
Otherwise, you can add a restricted-group section for the groups. ;-)
WAPT 1.5.1.9
Server: CentOS 7
hasop
December 29, 2017 - 12:18
Something else seems odd to me:
If I have a "restricted" package in a group (so the group is visible to the user in the portal), the package appears in the group's package list on the portal, and the user can therefore install it.
Shouldn't the package also be invisible in this list?
WAPT 1.5.1.9
Server: CentOS 7
December 29, 2017 - 12:25
No, the behavior is normal so far.
Dependencies are not impacted for the restricted version.
