[BETA] WAPT 1.5
Matthiman
Registration: August 27, 2015 - 1:23 PM
January 17, 2018 - 3:27 PM
dcardon wrote: Jan 16, 2018 - 6:32 PM I think I see where the problem is. For now, you can run the following commands:
`rm -f /var/www/wapt/
waptsetup-tis.exe` `apt-get install --reinstall tis-waptsetup`
I'll fix it tomorrow. I thought this bug was already fixed... sorry.
I followed the instructions correctly, but there's no change for me; the setup and agent are still at 1.5.13. I don't understand... I'll wait for the next version!
Matthiman
January 18, 2018 - 8:20 AM
Matthiman wrote: Jan 17, 2018 - 3:27 PM I followed the instructions correctly but there's no change for me, still on 1.5.13 for the setup and the agent, I don't understand... I'll wait for the next version!
I restarted it this morning, it's working!
THANKS ;)
joris.remandet
Registration: January 16, 2018 - 6:29 PM
January 22, 2018 - 8:34 PM
Even when waptconsole.exe and the wapt installation folder are excluded, it automatically ejects the executable. :(
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
January 23, 2018 - 5:14 PM
Hi,
I've had a strange issue since version 1.5.1.15. Some agents have correctly installed the wapt-upgrade 1.5.1.15 package, but in the wapt console, the wapt version column still shows 1.5.1.8...
And another odd thing is that some clients, while upgrading to 1.5.1.15, have corrupted themselves by removing Python libraries, making it impossible to restart the wapt service...
Have you ever seen this kind of behavior?
Thanks in advance,
guigeek
January 29, 2018 - 3:19 PM
Nobody? It happened to me again this morning.
guigeek wrote: Jan 23, 2018 - 5:14 PM Hi,
And another strange thing: some clients, when upgrading to 1.5.1.15, corrupted themselves by removing Python libraries, making it impossible to restart the wapt service...
Thanks in advance,
TomTomGo
Registration: May 3, 2017 - 3:36 p.m.
February 9, 2018 - 10:57
what is the correct order of operations when upgrading from version 1.3 to 1.5 using remote repositories?
We have set up a test WAPT infrastructure with a main central server and 12 remote repositories, currently at version 1.3.13.
Should we first update the tis-waptrepo package on all remote repositories and then update the main server?
Should we disable SyncThing replication beforehand? Or something else?
Thomas
February 9, 2018 - 11:31
Hello
, the documentation describes installing tis-waptrepo to install Apache.
In your case, you don't need to do anything on the remote repositories.
HOWEVER, BEWARE!
The migration from 1.3 to 1.5 requires all WAPT packages to be re-signed. This will generate traffic on all your remote repositories, so be mindful of your bandwidth!
Also, be aware that if you enable HTTPS certificate verification in version 1.5, you will need to replace the HTTPS certificates of the remote repositories.
TomTomGo
February 9, 2018 - 11:49
sfonteneau wrote: Feb 9, 2018 - 11:31 AM Hello,
The documentation says to install tis-waptrepo to install Apache.
HOWEVER, BEWARE!
The migration from 1.3 to 1.5 requires that all WAPT packages be re-signed. This will generate traffic on all your remote repositories, so be careful with your bandwidth!
Thank you for your response.
Yes, I had noted that all packages needed to be resigned, and that this would therefore result in a complete replication ;)
So there's no need to update the tis-waptrepo on the repo, ok, however they will remain at version 1.3.13, no problem?
Okay for the HTTPS certificate, I'll look into it more closely. Is there any documentation or tutorial for it?
THANKS
Nicoge
Registration: February 14, 2018 - 11:45
February 20, 2018 - 4:49 PM
Hello, I would like to know if version 1.5 is still in beta or not?
Because I see that the download links on the website and in the documentation (even for version 1.5) download the installation file for version 1.3.
Thank you.
agauvrit
Registration: Nov 17, 2016 - 10:25
February 20, 2018 - 5:18 PM
I don't want to spoil anything, but it's 21 days :roll:
until the next release. The links are being updated.
- Alexandre
