client with files on 2 different servers
cdeze
Registration: Nov 29, 2016 - 09:39
October 27, 2017 - 2:22 PM
is it possible to configure two different servers on the client: one for the /wapt-host and /wapt-group directories
, and one for the /wapt directory?
Basically, have the configurations on one side and the packages/installers on the other?
Thank you.
vcardon
November 13, 2017 - 9:19 PM
What use case can you think of that would require this level of complexity?
March 2, 2018 - 7:33 PM
Yes, it's possible; it can even have its own settings. You need to modify the wapt-get.ini file on the clients:
[wapt-host]
repo_url=https://wapthost.mydomain.lan/wapt-host
verify_cert=1
http_proxy=http://srvproxy:3128
