[RESOLVED] WAPT Server not working on Azure VM
itirla
Registration: February 28, 2018 - 4:54 PM
March 6, 2018 - 2:29 PM
I want to install the WAPT server on an Azure virtual machine with Windows Server 2016. I tried using Apache and IIS but without success.
With Apache I get the following error
With ISS I get the following message
Has anyone successfully installed WAPT Server on Azure?
Ioan
March 6, 2018 - 7:56 PM
In version 1.5 of WAPT, we no longer support IIS as a web server.
https://www.wapt.fr/fr/doc-1.5/waptserv ... -dans-wapt
Therefore, if possible, you should install WAPT without IIS and disable the IIS component (nothing should be listening on ports 80 and 443).
If you absolutely cannot disable IIS, you can always change WAPT's listening ports to no longer listen on 80 and 443. (The documentation is currently being written.) I will post it here once it is finished.
Regarding your problem, could you please provide more information?
- WAPT version
- Antivirus?
itirla
March 7, 2018 - 08:20
Thank you for your quick reply.
The WAPT server version is 1.3.13.0 and the antivirus is Windows Defender.
How can I download version 1.5 of the WAPT server?
Ioan
March 7, 2018 - 11:08
I've just updated the 1.5 documentation:
https://www.wapt.fr/fr/doc-1.5/Installa ... index.html
