[SOLVED] Problem creating the agent
March 20, 2018 - 11:50
There is :
  • waptsetup.exe (aka waptsetup-tis.exe)
  • waptagent.exe
If you are looking for waptsetup-tis.exe (which is waptsetup.exe) then you can download it from the address provided.
In your case, on a Wapt server running Windows, you have installed waptsetupserver.exe
Next, you must:
  • Open the console.
  • Generate a Wapt agent
The Wapt agent is then available at the following address: https://waptserver.mydomain.lan/wapt/waptagent.exe
Waptsetup is only useful if you want to generate the agent from somewhere other than the server.
If that's your choice, you might as well switch to Linux...
PPE
Registration: March 19, 2018 - 5:03 PM
March 20, 2018 - 2:11 PM
Okay, thank you. I think it's working this time. Thanks to your help, my installation seems to be functional.
