After updating the server and clients, I no longer have any active packages on my machines.
Is this normal?
If not, could you tell me what I might have missed?
Julien
Machine-related packages after upgrade from 1.3 to 1.5
- WAPT Expert
Indeed, I hadn't done things in the right order.
Otherwise, I have many errors of this type (approximately 50 machines out of the 133 reported):
Any ideas?
edit: it seems that WAPT is trying to install Chrome and crashes during installation even though it is not in the list of packages to install.
The script returns the following error:
SyntaxError: Missing parentheses in call to 'print' (line 3988, offset 20): 'print result'
This famous "print" is in setuphelpers.py on line 3988.
id;description;summary;start_date;logs;Created by
9;Installation de 0E304DF4-2B3B-1620-0916-094337000000 (=14) (tâche #9);Exception: Erreur lors de l'installation de 0E304DF4-2B3B-1620-0916-094337000000 (=14): erreurs dans les paquets [[u'0E304DF4-2B3B-1620-0916-094337000000 (=14)', PackageEntry('0E304DF4-2B3B-1620-0916-094337000000','14') ]];2018-03-21T14:10:06.048000;"Installing 0E304DF4-2B3B-1620-0916-094337000000
File ""C:\wapt\waptservice\waptservice.py"", line 1151, in run
self.running_task.run()
File ""C:\wapt\waptservice\waptservice_common.py"", line 405, in pwrapper
return func(*arg, **kwargs)
File ""C:\wapt\waptservice\waptservice_common.py"", line 464, in run
self._run()
File ""C:\wapt\waptservice\waptservice_common.py"", line 884, in _run
";None
- WAPT Expert
Hello jmeyer,
There was indeed a bug in the `run_powershell` function due to the Python 3 compatibility mode (`from future import print_function`). The bug has been fixed in the master version and will be included in the next WAPT release.jmeyer wrote: ↑March 21, 2018 - 2:33 PM edit: It seems that WAPT is trying to install Chrome and crashes during installation even though it's not in the list of packages to install.
This "print" command is in setuphelpers.py on line 3988.
