Empty package to uninstall an application
March 22, 2018 - 6:17 PM
    print('uninstalling Foxit Reader')
    for soft in installed_softwares('Foxit Reader'):
            error("Wapt find : %s" % soft)
benoitpatin
Registration: February 21, 2018 - 5:05 PM
March 23, 2018 - 10:37
It's still not working.
However, this time I have an error in the Tasks/Errors tab of the console:
Installing adv-Foxi-Reader-Uninstall
Installing 4C4C4544-0058-3410-8058-B3C04F304732
Exception: Erreur lors de l'installation de 4C4C4544-0058-3410-8058-B3C04F304732 (=33): erreurs dans les paquets [[u'adv-Foxi-Reader-Uninstall', PackageEntry('adv-Foxi-Reader-Uninstall','0-0') ], [u'4C4C4544-0058-3410-8058-B3C04F304732 (=33)', PackageEntry('4C4C4544-0058-3410-8058-B3C04F304732','33') ]]
  File "C:\Program Files (x86)\wapt\waptservice\waptservice.py", line 1150, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 408, in pwrapper
    return func(*arg, **kwargs)
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 467, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 887, in _run
March 23, 2018 - 2:04 PM
You need to send us the error message from your console when you click on the faulty package!
benoitpatin
March 23, 2018 - 2:23 PM
The error is the one I put in my previous message.
March 30, 2018 - 8:30 PM
Good evening Benoit,
benoitpatin wrote: ↑March 23, 2018 - 2:23 PM The error is the one I put in my previous message.
If the purpose of a package is to uninstall an application, the uninstallkey should not be specified, otherwise the package will inevitably fail because WAPT checks at the end of the def install() function that the uninstallkey is indeed present in the registry.
benoitpatin
April 4, 2018 - 11:50 AM
dcardon wrote: ↑March 30, 2018 - 8:30 PM Good evening Benoit,
Hi Denis!
Okay, so I removed the value of "uninstallkey".
However, can you confirm how to write the uninstallkey in the run command?
run(WAPT.uninstall_cmd(soft['Foxit Reader_is1']))
run(WAPT.uninstall_cmd(soft'{Foxit Reader_is1}'))
THANKS
benoitpatin
April 4, 2018 - 1:42 PM
KeyError: 'Foxit Reader_is1'
No matter what I put in run, I always get an error.
Couldn't we use the Uninstallstring instead?
