[Resolved] Problem updating wapt agent 1.5.1.22
Gaelds
Registration: Nov 22, 2015 - 08:37
March 28, 2018 - 10:09
Following the server update to version 1.5.1.22, I switched to a machine that had remained on version 1.3.13 for a few weeks (automatic agent updates often don't work on my network...). I therefore manually reinstalled the 1.5.1.22 agent on the machine, but it doesn't work (database disk is malformed error). Here is the complete message in the screenshot:
https://preview.ibb.co/nMLwN7/wapt1_5_1_22.png
March 28, 2018 - 10:32
I hadn't seen that before.
Apparently the small database of the wapt client is corrupted.
Simple solution: delete the .sqlite file. It is located in
<repertoire de wapt>\db\waptdb.sqlite
It will be recreated empty. The only problem is that dependent packages will reinstall themselves because the wapt client no longer knows what is installed.
Hubert
Gaelds
March 28, 2018 - 11:23
Thanks, I'll test that quickly! Perhaps it's due to an incomplete installation of agent 1.5?
EDIT: It works!
