[RESOLVED] Permissions on remote/secondary repositories
mart03
Registration: December 26, 2017 - 11:03
April 3, 2018 - 3:55 PM
Following the installation of a WAPT 1.5.1.22 server on a Debian 9 machine and a main repository, I set up 4 other secondary servers allowing me to replicate, however the permissions "jump" when the data is replicated on the secondary repositories, it only changes the www-data group to wapt.
This causes errors, particularly when a machine that has a secondary repository as a parameter and the server tries to install a package, it refuses access.
Example of the error:
Exception: Erreur lors de l'installation de alti-keepass (=2.38-24): erreurs dans les paquets [[(u'https://XXXXXXXX/wapt/alti-keepass_2.38-24_all.wapt', '403 Client Error: Forbidden for url: https://XXXXXXXXXXX/wapt/alti-keepass_2.38-24_all.wapt'), None], [u'alti-keepass (=2.38-24)', PackageEntry('alti-keepass','2.38-24') ]]
But when I add the correct group (www-data) to my packages on my remote servers it works.
My question is: How can we transfer packages/wapt-host without losing the permissions that are initially assigned?
Thank you for your help.
Martin
April 5, 2018 - 6:39 PM
To be a little more specific, are you using the synthesizing solution for replication?
mart03
April 6, 2018 - 9:56 AM
Oops, yes, absolutely, I use the Syncthing solution.
April 7, 2018 - 11:26
What does the command return?
groups wapt
mart03
April 24, 2018 - 4:10 PM
Sorry for the late reply.
Here's what the `groups wapt` command gives me:
Regards,
Martin
mart03
April 24, 2018 - 4:38 PM
I did some research, so I added the www-data group using the command:
adduser wapt www-data
And then change the primary group:
usermod --gid www-data wapt
Now we need to see if we can leave the other groups affected: cdrom, floppy, audio...
Or can they be detached from the user?
April 25, 2018 - 4:50 PM
Yes, normally in the current documentation, we install waptrepo (version 1.3).
This normally creates a wapt user with the www-data group
, and since we launch syncthing with the wapt user, normally the rights are correct.
mart03
April 26, 2018 - 09:04
Okay, thank you very much!
I think my mistake stems from the fact that I created a wapt user during the machine installation, so waptrepo couldn't create it and assign it to the correct group (in my opinion).
Martin
