- Installed WAPT version: 1.5.1.23
- Server OS: Linux Debian
after a fresh install of version 1.5, I wanted to install WaptSetup by downloading it from the web interface as described in the documentation: https://www.wapt.fr/fr/doc/Configuratio ... pt-console.
The link is the following and opens a 404 page : https://wapt.tranquil.it/wapt/releases/ ... tsetup.exe.
Has the address changed?
Thank you in advance for your reply.
problem downloading waptsetup
- WAPT Expert
Hello lowix,
However, it's true there's a bug with the link, but this link should only be used on Windows servers. We'll fix it; see the issue. https://roundup.tranquil.it/wapt/issue951 .
I think there are two problems here. The first is that you haven't installed the tis-waptsetup package as described here: https://www.wapt.fr/fr/doc/Installation ... postgresqllowix wrote: ↑Apr 20, 2018 - 2:17 PM - Installed WAPT version: 1.5.1.23
After a fresh install of 1.5, I wanted to install waptsetup by downloading it from the web interface as described in the documentation https://www.wapt.fr/fr/doc/Configuratio ... pt-console
The link is the following and opens a 404 page https://wapt.tranquil.it/wapt/releases/ ... tsetup.exe
