[RESOLVED] Computer Group and Package Group
david.debray
Registration: Nov 13, 2017 - 1:02 p.m.
April 5, 2018 - 3:58 PM
Hello everyone,
I'd like to create computer groups in the WAPT console. I work in a clinic, so for now I have 3 groups (easier for deploying my applications):
- IT
- Administration
- Care
I'd like to assign package groups (these groups already exist):
- BASE: Base package with WAPT and Fusion Inventory dependencies for inventorying the equipment
- Care: Programs related to care stations
- Administration: Programs related to administration stations
- IT: ... you get the idea ^^
- WAPTDEV: Packages for installing the WAPT console
All workstations in the domain should automatically receive the BASE package group as soon as they are detected by the console.
How can I do this?
OS Server: Debian Stretch (9.4)
WAPT Version: 1.5.1.23
OS Admin: Windows Server 2008 R2
April 6, 2018 - 12:08 PM
PiF wrote: ↑Apr 6, 2018 - 10:20 AM
But for now it doesn't work in 1.5.22 viewtopic.php?f=10&t=1070#p3698 :(
It should be tested in version 1.5.1.23, it should work.
tdejesus
Registration: August 22, 2017 - 4:39 PM
April 13, 2018 - 5:37 PM
I'm on version 1.5.1.23 and I have the same problem.
WAPT 1.8.1 Community
Server OS (Windows Server 2012 R2)
WAPT Client: 1.8.1
Client Machines: Running Win10x64
April 16, 2018 - 3:43 PM
Hello david.debray,
david.debray wrote: ↑Apr 5, 2018 - 3:58 PM All workstations in the domain should automatically receive the BASE packet group as soon as they are detected by the console.
How can I do this?
One way to do this is to assign a parameter when installing waptagent with waptdeploy, see. https://www.wapt.fr/en/doc/Configuratio ... index.html
david.debray
April 24, 2018 - 3:29 PM
OK, thanks, but that doesn't apply to my situation...
Let me explain: In the company, the GPOs were created by someone else without documentation or any apparent structure. :? Since I'm new, I'm avoiding touching them for now.
We're in the middle of a software migration, and I'm taking this opportunity to integrate the WAPT deployment into the batch script.
Here's what I'm using for WAPT:
`\\vm-admin\sa\waptagent.exe -updp "\\vm-admin\sa" /SILENT /NOICONS /SUPPRESSMSGBOXES /StartPackages=BASE`.
WAPT installs correctly, but the BASE package group isn't assigned to the machines... So I started adding
`wapt-get install BASE` to my script, but this option doesn't create any dependencies...
Is it possible to assign dependencies via the command line?
Sorry to be a pain :D. Thanks for any help!
April 27, 2018 - 1:35 PM
david.debray wrote: ↑Apr 24, 2018 - 3:29 PM OK thanks, but that doesn't apply to my situation...
WAPTDeploy can be used even outside of a GPO. It is much lighter than waptagent.exe, and only initiates the agent download when necessary.
david.debray wrote: ↑Apr 24, 2018 - 3:29 PM Let me explain: In the company, the GPOs were created by someone else without documentation or any apparent structure. :? Being new, I'm avoiding touching them for now.
We're in the middle of a software migration, so I'm taking the opportunity to integrate the WAPT deployment into the batch script.
The StartPackages option is supposed to launch the installation of the package on the machine after the agent is installed. However, it should launch the installation of the package and its dependencies after the agent is installed. If this is not the case, it's a bug.
david.debray wrote: ↑Apr 24, 2018 - 3:29 PM So I started adding:
`wapt-get install BASE` to my script, but this option doesn't create a dependency...
Can I assign dependencies via the command line?
Sorry to be a pain :D. Thanks for the replies!
It's normal that the package in question isn't automatically added as a dependency to the machine. "Machine package" configurations are signed by the administrator, and the signing key is, of course, not available on the workstations during deployment. If you want to do things differently, you'll need to use a less secure product :-)
However, the packages should indeed be present on the machine. A small caveat: /StartPackages uses the same methodology you indicated, that is, launching a wapt-get install BASETherefore, if the machine is restarted at that point, not all the packages may be installed. We will improve this by storing the current installation state in the local SQLite database, which will make the process more reliable.
david.debray
May 23, 2018 - 11:07
Thanks for the replies, but unfortunately I'm still stuck...
I tried:
The only solution I found with the Community version is to link an AD security group to a package group on the WAPT side. https://www.wapt.fr/fr/doc/Utilisation/ ... de-paquets
Then, populate this security group with the machines on the AD side.
A security group on the WAPT_SI DC with a corresponding packet group, I tested it with two different machines (just in case) :? ) no joy...
When I go to the console and run "Add AD groups as dependency packages," I get "machines ignored (error)."
The command: "waptdeploy.exe --hash=ef94a1f674fe9072d2cd7eb6f9fa0ab8d8d353d398a7c241a8eebabea25fd0d7 --minversion=1.5.1.23 --wait=15 /StartPackages=Compdinateurs" completes without error but does not create a dependency.
Any ideas? Thanks in advance for your help :D
