[SOLVED] Modification of MULTI_SZ value in the registry.
Imp83
Registration: February 19, 2018 - 12:07
June 8, 2018 - 08:21
I'm having trouble creating a pGina package. The installation goes smoothly, but the configuration involves modifying the registry, and when I try to modify a MULTI_SZ variable, I keep getting the error ValueError: Could not convert the data to the specified type which goes back up.
Here is the line of my script that is causing the problem:
registry_set(HKEY_LOCAL_MACHINE,r'SOFTWARE\pGina3',r'IPluginAuthentification_Order',r'0f52390b-c781-43ae-bd62-553c77fa4cf7 12fa152d-a2e3-4c8d-9535-5dcd49dfcb6d',type=REG_MULTI_SZ)
I should point out that my server is running community version 1.5.23 on Debian.
June 8, 2018 - 08:52
Try it with a list
registry_set(HKEY_LOCAL_MACHINE,r'SOFTWARE\pGina3',r'IPluginAuthentification_Order',['0f52390b-c781-43ae-
bd62-553c77fa4cf712fa152d-a2e3-4c8d-9535-5dcd49dfcb6d'],type=REG_MULTI_SZ)
Imp83
June 8, 2018 - 09:53
I tried it and everything works! Thank you so much!!
