I'm having trouble deploying the agent via GPO
I have correctly set up a machine GPO and I understand that the network is up to launch the GPO.
Using the command below as a local or domain administrator, it works; the WAPT agent installs
waptdeploy.exe --hash=myHash --minversion=1.5.1.23 --wait=15 use_fqdn_as_uuid=1 --waptsetupurl=https://srvwapt01/wapt/waptagent.exe
But nothing in GPO except under Windows 10 this gpo has no problems.
Windows 10 and Windows 7 have the same GPOs in my Active Directory
To simulate the installation under Windows 7 and Windows 10, I tested installing with psexec
see doc https://specopssoft.com/blog/how-to-bec...th-psexec/
"autorite nt\system"
Here is the error I got
c:\tmp>waptdeploy.exe --hash=maHache
acae2f7ab4c78 --minversion=1.5.1.23 --wait=15 use_fqdn_as_uuid=1 --waptsetupurl=
WAPT version:
WAPT required version: 1.5.1.23
Wapt agent path: C:\Windows\TEMP\waptagent.exe
Wget new waptagent from https://srvwapt01/wapt/waptagent.exe
Trying to reach https://srvwapt01/wapt/waptagent.exe...
Reachable, downloading...
Done.
Cleanup...
Unable to update immediately: Unable to download: http://127.0.0.1:8088/update.json?notify_server=1¬ify_user=0 HTTP Status: 0
An unhandled exception occurred at $00416608:
EFOpenError: Unable to open file "C:\Windows\TEMP\waptagent.exe"
$00416608
$004164B0
$00440216
$004047C9
WAPT version:
Wapt agent path: C:\windows\TEMP\waptagent.exe
Done.
SHA256 hash of downloaded setup file: 6f8d08eb448042eb1562063b93299093cec484e98936fcfbb3dacae2f7ab4c78
OK : Hash of waptagent match expected hash.
Got version: 1.5.1.23
Unable to speak with waptservice... continue (Unable to download: http://127.0.0.1:8088/tasks.json HTTP Status: 0)
Install ...
Launching C:\windows\TEMP\waptagent.exe /VERYSILENT /MERGETASKS=""useWaptServer""
Install OK : 1.5.1.23
Cleanup...
The system might not have the correct permissions?
I compared the permissions of C:\Windows\TEMP under Windows 10 and Windows 7 and it's the same
