Hello.
Is there a manifest or help file for WaptAgent options?
I'd
like to have the pre-installed WaptAgent packages automatically downloaded to the machine immediately after WaptAgent is installed.
I've searched on Google and found some great documentation for deploying to laptops across the network, but nothing in this thread.
Can package installation be launched using waptagent?
/r/ComedyCemetery/ "If I install Windows 10 of 32 bits twice... Will it become 64 bits?"
System Management Blog https://deployadmin.com/
In recent versions of wapt:
https://www.wapt.fr/fr/doc/Configuratio ... cieusement
command-line option for waptagent.exe: /StartPackages=apackage
or enter the macro set_start_packages in the file wapt\waptsetup\waptagent.iss before generating the custom wapt agent from the console.
to be checked.
; if not empty, a task will propose to install this package or list of packages (comma separated)
#define set_start_packages "unpaquet"Tranquil IT
