Update procedure
skoizer
Registration: June 19, 2018 - 4:45 PM
July 17, 2018 - 2:31 PM
- Installed WAPT version: 1.5.1.26
- Server OS: Linux CentOS
- Administration/package creation machine OS: Windows 7 64-bit
I followed the documentation
https://www.wapt.fr/fr/doc/waptserver_u ... entos.html
and generated a new agent
Is it normal that I have this on the server's web page : Database status: OK (1.5.1.23) ?
WAPT Server version: 1.5.1.26
WAPT Agent version: 1.5.1.26
WAPT Setup version: 1.5.1.26
WAPT Deploy version: 1.5.1.26
July 19, 2018 - 11:55
The basic database structure did not change between 1.5.1.23 and 1.5.1.26.
So this is not abnormal.
TheBarz
Registration: August 1, 2018 - 3:51 PM
August 8, 2018 - 10:41
the problem seems to be affecting agents as well, due to NSSM...
An exclusion seems to make the WAPT client functional, requiring a complete reinstallation...
agauvrit
Registration: Nov 17, 2016 - 10:25
August 8, 2018 - 2:56 PM
as mentioned in the documentation: https://www.wapt.fr/fr/doc/Frequent-pro ... -antivirus
TheBarz
August 10, 2018 - 3:42 PM
This does not appear to be sufficient.
The service is correctly registered, but the nssm.exe executable is deleted during installation by waptdeploy.exe.
September 5, 2018 - 11:17
It's definitely an antivirus problem
