Restarting the service after deploying a configuration
jlabadie
July 20, 2018 - 4:26 PM
To begin, here is some information regarding the infrastructure:
- Installed WAPT version: 1.5
- Server OS: Linux Debian 9 Stretch
- Administration/package creation machine OS: Windows 7
- One external WAPT server and two additional local repositories on each site
My problem:
I am currently deploying my wapt-get.ini configuration using a package
    print('Modify max_gpo_script_wait')
    inifile_writestring(WAPT.config_filename,'global','max_gpo_script_wait',180)
    print('Modify Preshutdowntimeout')
    inifile_writestring(WAPT.config_filename,'global','pre_shutdown_timeout',180)
    print('Disable Hyberboot')
    inifile_writestring(WAPT.config_filename,'global','hiberboot_enabled',0)
    print('Disable Notify User')
    inifile_writestring(WAPT.config_filename,'global','notify_user',0)
    print('Verify cert')
    inifile_writestring(WAPT.config_filename,'global','verify_cert',0)
    print('Modify public_certs_dir')
    inifile_writestring(WAPT.config_filename,'global','public_certs_dir','C:\Program Files (x86)\wapt\ssl')
    print('Modify repo_url')
    inifile_writestring(WAPT.config_filename,'global','repo_url','https://repolocal1/wapt')
    print('Create repositories')
    inifile_writestring(WAPT.config_filename,'global','repositories','repo-externe')
    print('Frequence update')
    inifile_writestring(WAPT.config_filename,'global','waptupdate_task_period',300)
    print('Timeout server')
    inifile_writestring(WAPT.config_filename,'global','wapt_server_timeout',300)
    print('Interdire annulation MAJ')
    inifile_writestring(WAPT.config_filename,'global','allow_cancel_upgrade',1)
    print('Enable repositories')
    inifile_writestring(WAPT.config_filename,'repo-externe','repo_url','https://repoexterne/wapt')
    print('Verify cert secondaire')
    inifile_writestring(WAPT.config_filename,'repo-externe','verify_cert',0)
This works when I add the package to a machine and allows me to modify the main repo in order to retrieve future packages from the local repo.
However, after testing, I realized that the service needed to be restarted, otherwise the retrieval of other packages is done on the externalized server's repo, therefore via HTTP.
The following command allows me to verify this:
wapt-get show "paquet"
I tried adding this little piece of code to my package:
def service_restart(WAPTService):
    logger.debug(u'Restarting service %s' % WAPTService)
    win32serviceutil.RestartService(WAPTService)
    win32api.Sleep(2000)
    return win32serviceutil.WaitForServiceStatus(WAPTService, win32service.SERVICE_RUNNING, waitSecs=4)
I have the impression that my service has restarted but I still am not retrieving the packages on the local repo.
If I manually restart the service the problem is solved, but I cannot afford to go to each of the 200 machines.
Sorry for the rather long post, but I tried to summarize the situation as best I could.
Thanks in advance and have a good weekend
July 20, 2018 - 4:52 PM
You can ask the service to schedule a restart (in the future)
Restarting the service while a package is being installed is not recommended...
import requests
    requests.get('http://127.0.0.1:8088/waptservicerestart.json')
jlabadie
July 23, 2018 - 09:09
By including that part of your script, the service is indeed restarted, but you have to wait a while for the following command to return the correct output from the repository:
That said, it's normal, but isn't there a better way to do it when creating a package that modifies wapt-get.ini?
July 23, 2018 - 3:48 PM
It could be something like this:
but some parameters will not be set (hiberboot_enabled, max_gpo_script_wait, pre_shutdown_timeout) because they are set when the service starts.
`def install():
WAPT.load_config()
WAPT.update(force=True)`
jlabadie
July 24, 2018 - 10:21
Okay, thank you, I will continue my tests
