WAPT1.3.13
Debian8
Win7&10
I performed a test update from 1.3.13 to 1.5. It works quite well. However, I would like to enable Kerberos for security reasons, but I get this error:
FATAL ERROR: EWaptBadServerAuthentication: Authentication failed on server https://....
I've already seen this topic, but I don't have a problem with the DNS SRV record: viewtopic.php?t=1060
When should I enable Kerberos? Is it better to do it during the initial postconf.sh or later?
Does it work under Debian 9? Perhaps a silly question, but what is the username/password to enter when running apt-get register?
Thank you
[SOLVED] Kerberos Problem
- WAPT Expert
When you enable Kerberos on the server, WAPT agents must attempt to register using a Kerberos ticket.
For this to work, the agent must have `use_kerberos = 1` in its configuration
(https://www.wapt.fr/fr/doc/Configuratio ... rveur-wapt).
When you generate an agent from the console, the "Use Kerberos for initial registration" checkbox enables this in the `waptagent.exe` file.
Yes, I've already checked the server and client configuration files, and I'm successfully generating the agent.
I reinstalled and finally switched to Debian 9.5.
I'm getting a new error:
`wapt-get register -S
.... HTTPError: 403 Error: FORbidden for url: https://...../add_host_kerberos`.
Is this an nginx configuration issue?
- WAPT Expert
Indeed, at the moment the post-conference is not very clean.
You must launch the postconf with the --use-kerberos option
Otherwise, indeed, the nginx configuration is not suitable for kerberos
/opt/wapt/waptserver/scripts/postconf.sh --use-kerberosKerberos authentication isn't working at all for me...
I followed the documentation step by step:
https://www.wapt.fr/fr/doc/Installation ... ebian.html (Ad Microsoft W2016)
Test 1:
Test on a client registered with AD (Computers) (use_kerberos = 1 on the client - use_kerberos = True, allow_unauthentificated_registration = False on the server):
waptservice User: (admin local)
Password: ***
HTTPError: 403 Error: FORbidden for url: https://wapt.0861234a.lan//add_host_kerberos
Test 2:
Test on a client registered with AD (Computers) (use_kerberos = 0 on the client - use_kerberos = True, allow_unauthentificated_registration = False on the server):
Password: ***
EWaptBadServerAuthentication: Authentication failed on server https://wapt.0861234a.lan for action add_host
Test 3:
Test on a client referenced on the AD (Computers) (use_kerberos = 0 on the client - use_kerberos = True, allow_unauthentificated_registration = True on the server):
Password: ***
The inventory was sent to the WAPT server (the machine appears correctly on the console
/var/log/nginx/error.log:
[error] *640 open() "/var/www/wapt-host/676.....wapt" failed (2: No such file or directory), client: IP, server: _, request: "GET ...
Conf client:
[global]
repo_url=https://wapt.0861234a.lan/wapt
send-usage_report=1
use_hostpackages=1
wapt_server=https://wapt.0861234a.lan
use_kerberos=1
check_certificates_validity=1
verify_cert=0
dnsdomain=
max_gpo_script_wait=180
pre_shutdown_timeout=180
hibertboot_enabled=0
Server conf: /opt/wapt/conf/waptserver.ini
[uwsqi]
http-socket = 127.0.0.1:8080
master = true
processes = 16
wsqi = waptserver:app
chdir = /opt/wapt/waptserver/
max-requests = 100
uid = wapt
gid = www-data
enable-threads = true
[options]
wapt_user = admin
wapt-password = ...
wapt-folder = /var/www/wapt
server_uuid = ...
secret_key = ...
use_kerberos = True
Test 1:
Password: ***
Test 2:
Password: ***
Test 3:
Password: ***
Conf client:
[global]
send-usage_report=1
use_hostpackages=1
use_kerberos=1
verify_cert=0
dnsdomain=
[uwsqi]
master = true
processes = 16
max-requests = 100
uid = wapt
gid = www-data
[options]
wapt_user = admin
wapt-password = ...
server_uuid = ...
secret_key = ...
use_kerberos = True
- WAPT Expert
In view of the error message
the nginx configuration is bad
add_host_kerberos returns 403 if --use-kerberos is not passed as an option (I just made a fix to make the postconf cleaner)
check your nginx configuration
if this is present in /etc/nginx/sites-enabled/wapt.conf:
So the postconf wasn't applied correctly
HTTPError : 403 Error : FOrbidden for url : https://wapt.0861234a.lan//add_host_kerberosadd_host_kerberos returns 403 if --use-kerberos is not passed as an option (I just made a fix to make the postconf cleaner)
location /add_host_kerberos {
return 403;
Okay, so I just ran the command
`/opt/wapt/waptserver/scripts/postconf.sh --use-kerberos` again
, and it does modify the contents of `/add_host_kerberos` in `/etc/nginx/sites-enabled/wapt.conf`.
I now have: `
auth_gss on;
auth_gss_keytab /etc/nginx/http-krb5.keytab;
proxy_pass http://127.0.0.1:8080;
However, it's still not working... I'm back to my initial error:
`EWaptBadServerAuthentication: Authentication failed on server https://wapt.0861234a.lan/ for action add_host_kerberos...`
Just to be clear, the WaptService User requested for registration is indeed a local admin account that needs to be provided? I tried with the domain admin and it's the same.
I still get this error:
Kinit works fine... klist too... msktutil OK - permissions OK.
We agree that we should clear the contents of the /etc/krb5.conf file and add this:
[libdefaults]
default_realm = MYDOMAIN.LAN
dns_lookup_kdc = true
dns_lookup_realm=false.
Just one thing, the "To verify, the command line echo $(hostname) should return the DNS address that the WAPT agents will use."
message only returns its machine name, namely wapt. Is that normal?
THANKS
I now have: `
auth_gss on;
[libdefaults]
THANKS
- WAPT Expert
No
As the documentation indicates "echo $(hostname) should return the DNS address that the WAPT agents will use"
otherwise your serviceprincipalname will not be correctly registered in the ad.
* Remove the machine account from the wapt server in the ad
* Delete the ticket /etc/nginx/http-krb5.keytab
Now restart the procedure from the beginning with a fully qualified domain name (FQDN) in your /etc/hostname file
- WAPT Expert
Hello James,
It is recommended to open a new topic for a new subject. I am closing this one as resolved.
