[SOLVED] problem update 1.5.1.23 to 1.6
cdeze
Registration: Nov 29, 2016 - 09:39
September 26, 2018 - 2:19 PM
I get this error message
Can you tell me if this resonates with you?
THANKS
root@wapt:~# apt-get update
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://cdn-fastly.deb.debian.org/debian stable InRelease
Ign:3 http://cdn-fastly.deb.debian.org/debian stable-update InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stable Release
Ign:5 https://wapt.tranquil.it/debian/wapt-1.6 stretch InRelease
Ign:6 http://cdn-fastly.deb.debian.org/debian stable-update Release
Ign:7 http://deb.debian.org/debian stable-update/main all Packages
Ign:7 http://cdn-fastly.deb.debian.org/debian stable-update/main all Packages
Ign:9 http://deb.debian.org/debian stable-update/main amd64 Packages
Ign:9 http://cdn-fastly.deb.debian.org/debian stable-update/main amd64 Packages
Ign:10 http://deb.debian.org/debian stable-update/main Translation-en
Ign:10 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-en
Ign:11 http://deb.debian.org/debian stable-update/main Translation-fr
Ign:11 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-fr
Ign:12 https://wapt.tranquil.it/debian/wapt-1.6 stretch Release
Ign:13 http://deb.debian.org/debian stable-update/main Translation-en_US
Ign:13 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-en_US
Ign:14 http://deb.debian.org/debian stable-update/contrib amd64 Packages
Ign:14 http://cdn-fastly.deb.debian.org/debian stable-update/contrib amd64 Packages
Ign:15 http://deb.debian.org/debian stable-update/contrib all Packages
Ign:15 http://cdn-fastly.deb.debian.org/debian stable-update/contrib all Packages
Ign:16 http://deb.debian.org/debian stable-update/contrib Translation-en_US
Ign:16 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-en_US
Ign:17 http://deb.debian.org/debian stable-update/contrib Translation-en
Ign:17 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-en
Ign:18 http://deb.debian.org/debian stable-update/contrib Translation-fr
Ign:18 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-fr
Ign:19 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main amd64 Packages
Ign:20 http://deb.debian.org/debian stable-update/non-free all Packages
Ign:20 http://cdn-fastly.deb.debian.org/debian stable-update/non-free all Packages
Ign:21 http://deb.debian.org/debian stable-update/non-free amd64 Packages
Ign:21 http://cdn-fastly.deb.debian.org/debian stable-update/non-free amd64 Packages
Ign:22 http://deb.debian.org/debian stable-update/non-free Translation-fr
Ign:22 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-fr
Ign:23 http://deb.debian.org/debian stable-update/non-free Translation-en
Ign:23 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-en
Ign:24 http://deb.debian.org/debian stable-update/non-free Translation-en_US
Ign:24 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-en_US
Ign:25 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main all Packages
Ign:26 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-en
Ign:27 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-en_US
Ign:28 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-fr
Err:9 http://deb.debian.org/debian stable-update/main amd64 Packages
  404  Not Found
Err:19 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main amd64 Packages
  gnutls_handshake() failed: Error in the pull function.
Reading package lists... Done
W: The repository 'http://deb.debian.org/debian stable-update Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'https://wapt.tranquil.it/debian/wapt-1.6 stretch Release' does not have a Release file.
E: Failed to fetch http://deb.debian.org/debian/dists/stable-update/main/binary-amd64/Packages  404  Not Found
E: Failed to fetch https://wapt.tranquil.it/debian/wapt-1.6/dists/stretch/main/binary-amd64/Packages  gnutls_handshake() failed: Error in the pull function.
E: Some index files failed to download. They have been ignored, or old ones used instead.
September 26, 2018 - 3:13 PM
Hello cdeze,
cdeze wrote: ↑September 26, 2018 - 2:19 PM I get this error message
THANKS
I think you're having a problem with your APT download... Could you check your proxy? Is there any man-in-the-middle (MITM) attack using a wildcard certificate on your proxy?
cdeze
September 26, 2018 - 4:03 PM
Good morning
No MITM, but rather a proxy that must not know a cipher or an SSL version
FYI
root@wapt:~# curl -vv https://wapt.tranquil.it/
*   Trying 100.78.56.201...
* TCP_NODELAY set
* Connected to (nil) (100.78.56.201) port 8001 (#0)
* Establish HTTP proxy tunnel to wapt.tranquil.it:443
> CONNECT wapt.tranquil.it:443 HTTP/1.1
> Host: wapt.tranquil.it:443
> User-Agent: curl/7.52.1
> Proxy-Connection: Keep-Alive
< HTTP/1.1 200 Connection established
* Proxy replied OK to CONNECT request
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* Unknown SSL protocol error in connection to wapt.tranquil.it:443
* Curl_http_done: called premature == 1
* stopped the pause stream!
* Closing connection 0
curl: (35) Unknown SSL protocol error in connection to wapt.tranquil.it:443
cdeze
September 26, 2018 - 4:12 PM
I think my proxy only allows TLS 1.3 and your server doesn't have that protocol
. Am I wrong?
September 26, 2018 - 4:16 PM
Hello Cdeze,
cdeze wrote: ↑Sep 26, 2018 - 4:12 PM I think my proxy only allows TLS 1.3 and your server doesn't have this protocol
. Am I wrong?
I think your proxy doesn't support TLS 1.2... If your proxy only accepts TLS 1.3, it won't be able to connect to much! :-)
cdeze
September 26, 2018 - 4:22 PM
Yet he does:
root@wapt:~# curl -vv https://forum.tranquil.it/
* TCP_NODELAY set
* Establish HTTP proxy tunnel to forum.tranquil.it:443
> CONNECT forum.tranquil.it:443 HTTP/1.1
> Host: forum.tranquil.it:443
* ALPN, offering h2
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server accepted to use http/1.1
* Server certificate:
*  subject: OU=Domain Control Validated; OU=Gandi Standard Wildcard SSL; CN=*.tranquil.it
*  start date: May 25 00:00:00 2018 GMT
*  expire date: Jun  8 23:59:59 2020 GMT
*  subjectAltName: host "forum.tranquil.it" matched cert's "*.tranquil.it"
*  issuer: C=FR; ST=Paris; L=Paris; O=Gandi; CN=Gandi Standard SSL CA 2
*  SSL certificate verify ok.
September 26, 2018 - 5:21 PM
Hello cdeze,
cdeze wrote: ↑September 26, 2018 - 4:22 PM Yet he does:
We're also using a proxy; I have the same TLS and cipher in both cases... I admit I don't understand...
[dcardon@srvlts1.ad.tranq ~]$ curl -vv https://wapt.tranquil.it/
* Trying 192.168.149.13...
[dcardon@srvlts1.ad.tranq ~]$ curl -vv https://forum.tranquil.it/
Simon told me that, in the worst-case scenario, you can always download the .deb files using your browser and install them with dpkg... :-)
cdeze
September 27, 2018 - 08:46
The problem stemmed from our filtering at Bluecoat, which had flagged the site as suspicious.
Sorry
October 2, 2018 - 8:04 PM
Hello Cdeze,
cdeze wrote: ↑Sep 27, 2018 - 8:46 AM The problem came from our filtering at Bluecoat, which had flagged the site as suspicious.
Sorry
Thanks for the feedback, I'm marking the topic as [RESOLVED]
