BadZipFile: Bad CRC-32
kira249
Registration: December 10, 2018 - 1:20 PM
December 10, 2018 - 1:29 PM
Currently at version 1.6.2.7, I needed to modify a package from the IT repository, the NSCLIENT package, to update it to the latest version of the executable and add my .ini configuration file
The build and upload process completes correctly; however, when I try to deploy the package or even re-download it to modify it, I get an error. I've had to delete my package 5 times without being able to fix the problem
If a kind soul would be willing to take the time to help me out of this debilitating situation, I would be very grateful. ^^
Here is the error log:
File "C:\Program Files (x86)\wapt\waptpackage.py", line 1714, in unzip_package
raise e
custom_zip.BadZipFile: Bad CRC-32 for file u'NSCP-0.5.2.35-x64.msi'
and in the photo:
