[SOLVED] Testing if a package is installed
Patrice_minagri
Registration: Oct 21, 2016 - 4:56 p.m.
January 10, 2019 - 5:18 PM
could you help me find the Python instructions that test for the presence of a WAPT package on the workstation?
I know the `installed_softwares` function, but it only processes the application name from the list of installed applications. What I need is to determine whether or not a package is present by its name.
I'm a bit stuck here!
Thanks.
Patrice
WAPT 2.6.1.17787
January 10, 2019 - 5:25 PM
    if WAPT.is_installed('tis-firefox'):
       print(u'Paquet firefox installé')
Patrice_minagri
January 10, 2019 - 5:41 PM
Thank you so much !!!!
WAPT 2.6.1.17787
