[RESOLVED] nginx 504 gateway timeout when upgrading to 1.7
olivetree
Registration: February 19, 2018 - 10:42
February 18, 2019 - 11:24
Good morning.
Windows Server 2012r2
Testing the upgrade from version 1.5 to 1.7
Manipulation performed
1) Backup of configuration files
2) VM backup
3) WAPT* services discontinuation
4) WAPT update from 1.5 to 1.7
5) Launch of WaptConsole
time out
A netstat from the server indicates that wapt is listening on port 443 but not on port 80
6) Launching WaptConsolePostConf
I have a result, whereas in version 1.5 it was functional.
/r/ComedyCemetery/ "If I install Windows 10 of 32 bits twice... Will it become 64 bits?"
System Management Blog https://deployadmin.com/
olivetree
February 18, 2019 - 1:14 PM
I don't know how to mark this as "Resolved".
The problem was between the chair and the keyboard.
The shutdown of services related to WAPT Server, particularly nginx, wasn't done properly.
Sorry for the inconvenience.
Elminio
Registration: February 19, 2016 - 3:39 PM
February 18, 2019 - 2:10 PM
You need to edit your message and add [RESOLVED] to the title.
Can you confirm that your WAPT server is communicating correctly with your client machines?
I also need to perform this update.
Regards,
Elminio
olivetree
February 18, 2019 - 4:31 PM
Good morning.
Yes, my server communicates with clients.
I just had to ensure the (clean) shutdown of services related to WAPT and of course proceed with the update as a local admin.
