Hello everyone,
I'd like to install one package first, before all the others. I understand dependencies in the control panel, but that's not enough. Let me explain. I deploy my agents and assign a dependency list to an OU; so far, so good. The problem is that one of my dependencies is the package that allows me to modify my wapt-get.ini file and therefore configure my local repository. If the package isn't applied and my WAPT service hasn't been restarted, they download the software from my main repository...
How can I fix this? I have many workstations behind it.
Thanks
, Bastien
Installation order
It's worth what it's worth, but for a roughly similar problem, we chose to install the wapt-get.ini configuration package via a startup script. which is executed on the first startup of the machine.
That said, it doesn't solve the problem when moving a machine without reinstalling.
Hopefully this might help a little.
Good day.
Seb
wapt-get install xxx-waptserverconfigThat said, it doesn't solve the problem when moving a machine without reinstalling.
Good day.
Seb
Hello, thank you for the reply. That's indeed what I did in a batch file like the one below. It's a bit of a hack, but oh well. I thought there was a built-in method or logic for choosing the first package the client installs. I tried creating a package with a name like s-yyyyyyy or s-0a, but no, it doesn't install first.
`ipconfig /flushdns` `
ping 127.0.0.1`
`gpupdate /force` `
ping 127.0.0.1`
wapt-get remove monpaquetconfigwaptgetini`
-get install monpaquetconfigwaptgetini` `
127.0.0.1`
`service stop watservice` `
ping
service start watservice` `
127.0.0.1`
`wapt-get update`
`ping 127.0.0.1`
`wapt-get upgrade`
ping 127.0.0.1`
`gpupdate /force` `
ping 127.0.0.1`
127.0.0.1`
ping
127.0.0.1`
`wapt-get update`
`ping 127.0.0.1`
`wapt-get upgrade`
3 x Server: Debian 9.6
104 + 8 + 3 Remote Windows Repositories
Wapt: 1.6.2.7 Enterprise
Console: Windows 10 Pro
