Package uninstallation failed
Alexis83
Registration: Apr 16, 2019 - 5:48 p.m.
April 17, 2019 - 09:27
Hello everyone,
I just set up a WAPT server on Debian 9 to test this tool, which looks amazing!
I'm in the testing phase, doing the most basic things possible.
I manually deployed the agent on three machines and deployed some packages initially.
However, when I try to uninstall a package, for example, CCleaner, nothing happens...
I used the forced uninstallation function, but it didn't work.
Is there a way to uninstall a package via the console, or do I always have to use the machine and the URL "http://127.0.0.1:8088"?
Thank you for your help.
Best regards,
Alexis.
April 23, 2019 - 3:56 PM
In the console, select the workstation, and then right-click on the package in the list on the right / uninstall package
Alexis83
April 24, 2019 - 12:01
Thanks, I'll try it that way. I didn't think of that!
Alexis83
April 24, 2019 - 12:08 PM
It's not that I didn't think of it, I just don't have the option. There's no such option.
I double-click on the computer, and in the right-hand pane, there's no option to uninstall the package. :(
The "Block packages" option to force uninstallation doesn't work either.
