[SOLVED] HTTP/1.1 404 Not Found
Glasgow
Registration: June 24, 2019 - 4:43 PM
June 24, 2019 - 4:56 PM
Hello, I recently installed Waptserver version 1.7.4.6077 on a VM (Windows Server 2008). I completed the entire installation, but when I try to authenticate, I get the following message: "Error on the WAPT server: HTTP/1.1 404 Not Found."
Any ideas on how to resolve this issue? Thank you in advance for your help.
June 24, 2019 - 6:44 PM
Hello Glasgow,
Glasgow wrote: ↑June 24, 2019 - 4:56 PM Hello, I recently installed Waptserver version 1.7.4.6077 on a VM (Windows Server 2008). I completed the entire installation, but when I try to authenticate, the following message appears: "Error on the WAPT server: HTTP/1.1 404 Not Found."
Any idea how to resolve this issue? Thank you in advance for your replies.
My crystal ball is broken, but my intuition tells me there's already a web server other than WAPT's running on this machine. If that's not the case, we'll need a bit more context to find an explanation :-)
Glasgow
June 25, 2019 - 4:47 PM
This morning I was able to access the console without any problems, but recently it's back to the same message as yesterday and I can't access the WAPT console
June 25, 2019 - 11:02 PM
To verify Denis's theory:
Verify that port 8088 is listening on the machine:
netstat -ano | find ":8088"
The order must return:
TCP     0.0.0.0:8088    0.0.0.0:0       LISTENING       3916
The value 3916 represents the ID of the process that is using the port.
To verify that it is indeed the WAPT server using this port, you can list the processes and filter by the ID returned previously using the command:
tasklist | find "3916"
waptpython.exe  3916  Services          0  34 860 Koa
The same applies to ports 80 and 443, but in this case, it shouldn't be waptpython.exe that responds, but nginx.exe
You can also provide us with the status of the WAPT service in services.msc
Glasgow
June 26, 2019 - 11:05
Thank you for your response
For port 8088, the order returns
TCP   127.0.0.1:8088      0.0.0.0.0     LISTENING      1660
and indeed the find me command returns
waptpython.exe        1660 Services     0       57 452 Ko
Ports 80 and 443 are responding correctly to nginx.exe
June 26, 2019 - 11:41
Oops, my mistake, try with port 8080 and not 8088
Glasgow
June 26, 2019 - 12:00
Ah yes, indeed, it's Java that uses that port, thank you very much
June 26, 2019 - 12:39
Glasgow wrote: ↑June 26, 2019 - 12:00 Ah yes, indeed, it's Java that uses this port, thank you very much
You should carefully reread the first recommendations on this page: https://www.wapt.fr/fr/doc/waptserver-i ... index.html
