[SOLVED] Configuring FusionInventory
Quentin
Registration: July 18, 2019 - 08:49
July 18, 2019 - 4:50 PM
I am currently experiencing a problem with the FusionInventory package on my WAPT system.
The package installs successfully on my server and on the various client machines, but the configuration is not applied.
Here is the configuration of the "Setup.py" file:
Here's what my Agent displays on the PC:
WAPT version: 1.5.1.23
Server OS: Windows Server 2016
Operating System: Windows 10
Thank you for your answers.
July 19, 2019 - 6:46 PM
Hello Quentin,
Quentin wrote: ↑July 18, 2019 - 4:50 PM I'm currently having a problem with the FusionInventory package on my WAPT server.
The package installs correctly on my server and on the various client machines, but the configuration isn't being applied.
Here's the configuration from the "Setup.py" file:
There are no obvious errors in your script. I advise you to test it in debug mode in PyScripter with a breakpoint and check each variable.
Quentin wrote: ↑July 18, 2019 - 4:50 PM WAPT Version: 1.5.1.23
Machine OS: Windows 10
I strongly encourage you to upgrade to version 1.7, it includes a large number of fixes and improvements compared to version 1.5.
Denis Cardon
Quentin
August 12, 2019 - 3:05 PM
thank you for your reply.
I updated my WAPT server to the latest available version, but the problem persisted.
To resolve it, I applied a Group Policy Object (GPO) that modified a registry key to specify the path to my FusionInventory server.
Have a good day
August 12, 2019 - 8:31 PM
To do this with Wapt:
https://www.wapt.fr/fr/doc/wapt-create- ... gistry-key
In my opinion, you just need to add the option `force=True a install_exe_if_needed` to the previous code.
